Please post a schematic.
Ken
All,
I am getting back into electronic design after being out of if for a while. I have designed a voltage regulator circuit and it works well as designed, and is a power supply. about 24VDC and could pull as much as 5A. I need to be about to protect it from someone connecting the terminals in backwards. I have an LED that will come up when the system is working properly. Are diodes the best way?
Ken
KMoffett,
here is the schematic that is connected to the bus. There is some other circuits down stream from this on but I figured if I could protect this one then the rest will also be protected.
Thanks for the help...
A single diode in series with the (+) input would prevent damage due to reversal of input polarity. A low Vf Schottky diode would be the most efficient. There are active polarity-reversing protection circuits with almost no voltage drop, but for your boost circuit it would be a waste.
Ken
One test is worth a thousand expert opinions, but one expert specification is worth a thousand tests.
If i miss something you posted or something you think is important, feel free to PM me.
My goal is to protect the circuit from a user error. The most likely one will be connecting the positive terminal of the battery to gnd of my circuit and the gnd terminal of the battery to the vin of my circuit. I am engineering controls into the installation instructions but they are not always followed as they should be and don't want to be replacing the board all the time.
Thanks!
I tested a shottky diode in this configuration and it did not protect my circuit when I reverced my input terminals.
Just about all IC's will take a negative supply of 0.7 vdc. You can use a large amperage rated diode but you need an input fuse that will blow when the diode conducts due to reverse polarity. The diode amperage rating needs to be higher then the fuse amperage.
Most DC-AC inverters use this approach to protect against reverse polarity connection.
So what happened when it did "not protect my circuit "?
I had suggested that you place the diode in series with the (+) input, not in series with the ground. With the diode in the ground input, the output ground will be ~0.3V more positive than the input ground. This will be a problem if any of the load circuits needs to have a common ground with the 24V input.
Ken
Ken,
what happened was that it fried the the vreg chip.
I know that you said to put it series with the + input. I have not had a chance to test that. I am wondering how that will work to protect it? Do you think it needs a fuse? If so what would be the configuration. I really appreciate this I am trying to learn it has been almost 10 years sence I have done circuit design.
Thanks!
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| is reading lots of schematics the best way to learn? | psasidisrcum | General Electronics Chat | 19 | 29th December 2008, 06:11 PM |
| What is the best way to connect amp and recorder? | jasonbe | General Electronics Chat | 6 | 22nd September 2008, 04:57 PM |
| Anyone here use the PICLIST? What's the best way to post? | blueroomelectronics | Microcontrollers | 6 | 15th April 2008, 10:56 AM |
| What's the best way... | Desp | General Electronics Chat | 8 | 28th October 2007, 06:06 AM |
| What's the best way to defeat surveilance ? | Nostrafus | Electronic Projects Design/Ideas/Reviews | 54 | 27th September 2004, 09:27 PM |
