diode placement
  1. #1
    swilsonNC swilsonNC is offline
    diode placement
    Is it better to place a diode in series with a 12V DC input or in parallel from input to ground for reverse voltage protection? Also what diode would be best for 12 - 14Vdc and a max of 200mA?
  2. #2
    ronv ronv is offline
    Usually series is better because it protects without blowing a fuse. Generally a schottky diode like the 1N5817 would be used to keep the voltage drop low, but if the diode loss is not a problem a 1N400X type would also be ok.
    0
  3. #3
    unclejed613 unclejed613 is offline
    both methods are used. putting the diode in series means you lose 0.7v across the diode. putting the diode across the power terminals requires a high current diode, preferably rated at a higher current than the fuse (always use a fuse). i've seen these diodes used in CB radios, and often they are 1N4004's. the problem is that if the radio is fused for 5 amps, and the diode is a 1 amp type, the diode often shorts, then burns open before the fuse blows. then all the expensive parts that were supposed to be protected, get hit with the reverse voltage the diode was protecting against. if the device needs to be fused for 5A, then use a 6A diode.
    actually, come to think of it a series diode needs to be rated at a current higher than the load will draw. losing that 0.7V often isn't a problem, except for things with audio amplifiers or transmitters inside where you want Vcc to be as high as possible. i get a lot of car audio to work on, and all the manufacturers use a diode across the power terminals.
    0
    E=mc˛ (+/-1dB)
    "If a curl of smoke is seen, the technician will soon experience the cause of difficulty"........ CTX arcade game monitor service manual 1985
    DC-to-Daylight Blog (on this forum):
    http://www.electro-tech-online.com/blogs/unclejed613/
    Vintage Audio and Pro-Audio Repair, ampz(nospam-removethis)@sohonet.net
    fight spam: http://www.robietherobot.com/spamfight.htm
    http://www.spamhelp.org/harvesterkiller/
varactor diode droid Datasheets, Manuals or Parts 4 22nd May 2003, 03:18 AM
How to operate a laser (diode?) SeanHatch General Electronics Chat 4 17th May 2003, 02:31 PM
Diode Help Please thebigbasicq Electronic Projects Design/Ideas/Reviews 5 6th May 2003, 11:05 AM
photo diode ? pmepal General Electronics Chat 1 5th May 2003, 04:52 PM
diode detectors Michael Cotter General Electronics Chat 3 14th November 2002, 04:23 PM
Page Time: 0.06470 seconds      Memory: 7,232 KB      Queries: 16      Templates: 0
