Newb here! Disable overrun Timer on Extractor Fan?
12 Last »
  1. #1
    kujina kujina is offline
    Hi I’m new, I have a extractor fan Vent-Axia Lo-Carbon Silhouette 150 and I’d like to be able disable the overrun timer completely (the shortest turn off time is about 3 mins). I’d want to leave the humidity sensor working though.
    The reason I’d like to do this is that I have a special switch (Sensorbility) with a sensor that projects a proximity sensing field through materials (it will be hidden behind a small tile) enabling anyone to switch the extractor fan on and off. This will be better than the usual wiring off of a light switch. This special bathroom switch has its own overrun timer.
    I can solder and I just bought a proper hot iron / hot air combo station. I’d be really grateful if anybody tell me if it’s possible to just disable the overrun timer on this extractor fan. I don’t really know much at all about electronics, soon I will start learning, I’m going to buy Make: Electronics: Learning Through Discovery by Charles Platt.
    ...Thanks...
  2. #2
    simonbramble simonbramble is offline
    that potentiometer, labelled T - the one that is turned most clockwise - is probably the timer adjustment in question. If you alter this, does it alter the timeout period? This will probably be in series with another resistor. Turning it far clockwise takes the resistance to its minimum and the extra resistor is the residual 3 minutes. therefore you want to lower this fixed resistor. I would lower it, but not reduce it to zero (I dont like zero ohms in any circuit).
    This is just a guess, but probably how it works. I have an en suite timer with the same problem. The above worked for me
    0
    For an interactive guide to LTSpice and Switched Mode Power Supply Design:
    LTSpice Tutorial
  3. Thread Starter #3
    Thanks for responding! That’s great if a change of resistor is all it needs. Yes the potentiometer labelled T is how you increase and decrease (clockwise) the time, the potentiometer labelled H is for adjusting the humidity level at which the fan will start automatically (I don’t want to affect that).
    If you look at the second photo, its of the back of the board and the potentiometer T is now on the left at the bottom, any pointers?
    ...Thanks...
    0
  4. #4
    alec_t alec_t is offline
    It looks as though R27 is a 12k4 resistor in series with the 'T' pot (you could confirm with a meter check). Perhaps you could connect another resistor (say 10k or even lower) in parallel with that and see if it reduces the time? In line with what simonbramble says I wouldn't reduce that resistance to zero though, unless you can be sure of not letting the magic smoke out.
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  5. Thread Starter #5
    Hello Alec
    Just been looking at Wikipedia (I’m a proper newbie) to work out what the resistor numbers mean and I see how the R27 resistor is 12.4k ohms, is 12k4 another way it can be written down?
    To confirm the resistor is in series with the'T' pot, where do I place the probes and what should I measure for?
    When you say "connect another resistor (say 10k or even lower) in parallel would that mean to remove (assuming it’s the correct one) the R27 resistor and put a lower one in its place?
    0
  6. #6
    12k4 is another way of writing 12.4k (it is done this way so you dont have to worry about missing a decimal point). Putting any resistor in parallel with the 12.4k WILL (and always will) bring down the overall resistance. Putting the same resistor in parallel with any resistor halves the value, so you can try putting in another 12k resistor (or similar). I suspect C10 is the capacitor it is charging, so if you were to probe anything, you need to probe the voltage across C10. personally I would just add a 10k (or 12k or something near to that value) across R27 and see what happens. Measure the resistance of the 10k before you do it, just to make sure it is not 10 Ohms.
    0
    LTSpice Tutorial
  7. #7
    Yes. It's a convention where the decimal point is replaced by a multiplier (e.g. k, M, μ) for clarity, as points don't show up well.
    Set your meter to measure Ohms, on the 20kOhm range, and put the probes on points 2 and 4. You should get a reading of ~ 12k4.
    No. Leave R27 as is and just connect another resistor between points 2 and 3 (or optionally between points 2 and 4 if your meter test gave the expected ~12k4 reading. This will test your soldering skills! Make sure you don't get any solder blobs causing short circuits.
    0
    Alec's First Law:-
  8. Thread Starter #8
    I set my meter to measure Ohms, on the 20kOhm range, and put the probes on points 2, 4 and tried 2, 3 and I get a reading of 8.02 ?
    0
  9. #9
    That's reasonable, as there is presumably something else effectively connected across points 2,3. So, at your own risk, you could try temporarily connecting 10k between 2 and 4 (probably easier than between 2 and 3). In theory that should roughly halve the over-run time and you can work down from there with a lower value resistor. Unless you can post the full schematic of the control circuit, suck it and see seems the only approach.
    But BE CAREFUL. Ensure mains power has been off for at least 30 secs before working on the circuit.
    0
    Alec's First Law:-
  10. Thread Starter #10
    Well I put a 10k resistor between points 2 and 4 and it seems to add another minute to the time! Timing it properly the fan seems to actually average about 2 mins 20 sec of overrun as standard. With this resistor in place it runs for about 3 mins 20 sec.
    The resistance of R27 is about 8k normally, when I added the 10k resistor the reading is about 4k4
    0
12 Last »
Clever(?) way of controlling the extractor fan in my ensuite... robnorton Electronic Projects Design/Ideas/Reviews 0 22nd February 2010, 04:46 PM
12v fan relay and timer diagram horspiste Electronic Projects Design/Ideas/Reviews 16 11th January 2010, 05:37 PM
Timer circuit for 12v car fan (to body solenoid) xjstevie Electronic Projects Design/Ideas/Reviews 0 11th November 2009, 10:24 PM
Fan run-on timer Jay666666 General Electronics Chat 18 9th March 2009, 01:23 PM
Need help to build a fan timer Vargtass Electronic Projects Design/Ideas/Reviews 4 26th December 2003, 10:51 AM
Page Time: 0.10055 seconds      Memory: 7,667 KB      Queries: 16      Templates: 0
