Power Supplies - Which are low standby?
  1. #1
    rnorman3 rnorman3 is offline
    Hello, just wondering, I want to buy an 'adapter', such as from 120VAC to 9VDC 2A. I want to have one that has the lowest standby power from the wall.
    So for example if the load on the output is zero, then I would expect the adapter to be loading the 120V side with little to nothing. However I understand in most adapters the 120VAC goes immediately into a transformer, so that's quite a load already. I seen some adapters marked an "input: 120VAC, 11W" so I assume that's even with no load on the output.
    I seen also some switching power supply adapters, but I'm not sure what the standby is like on those, are they less? Any recommendations?
    Thanks.
  2. #2
    ronsimpson ronsimpson is offline
    Quote Originally Posted by rnorman3 View Post
    Thanks.
    I would not assume that.
    0
  3. #3
    Reloadron Reloadron is offline
    Well I guess you could start this way. Ac/DC adapters like this are commonly called wall warts. So plug a wall wart into the wall (for want of a better place to plug it into) and wait a while. Unloaded does it get warm? Yes, so some power is doing nothing. No getting around it, you plug an unloaded transformer into the wall and it gets warm so it cost something. Even a switching PSU unloaded will get warm so it cost something. If it makes heat from electricity it cost.
    A 9VDC wall wart rated for 2 amps will draw 9 * 2 = 18 watts. Oh but wait, that would be 18 watts plus the loss. How efficient is the wall wart?
    When you say:
    I would assume under full load conditions,
    While I have never delved into this much it works as follows. I pay about 7 cents (USD) per KWH for electricity. Running a max load of 2 amps at 120 VAC is 240 watts. So under full load a wall wart delivering 25 watts cost me about how much?
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  4. #4
    I am looking at a "EPS060100" power supply that outputs 6 watts and under no load it draws 0.5 watts.
    0
  5. Thread Starter #5
    OK, so would a switching PS use less power in standby than a non-switching?
  6. #6
    yes! yes!
    0
  7. #7
    bountyhunter bountyhunter is offline
    Not correct, that is the spec with rated load on the output.
    Thanks.
    Depends, going into standby is a high level feature not found on most cheap power supplies.
    0
  8. #8
    It totally depends on the design. The switcher might have an offline bias rail to run on that has to stay alive all the time. It varies.
    0
  9. #9
    Recently most switching adapters have a very low standby power. It is almost imposable to sale one that uses more than 1 watt.
    (green power)
    0
Op amp power supplies blabley General Electronics Chat 10 6th January 2007, 02:04 PM
Power Supplies Kane2oo2 General Electronics Chat 8 22nd November 2003, 06:42 PM
testing power supplies aquaiet General Electronics Chat 3 27th July 2003, 02:40 AM
Need help testing AC/DC power supplies wasman Electronic Projects Design/Ideas/Reviews 3 25th July 2003, 03:56 AM
AMP ratings on power supplies vanhin General Electronics Chat 2 28th June 2003, 06:12 PM
Page Time: 0.10197 seconds      Memory: 7,638 KB      Queries: 16      Templates: 0
