Finding problem (with Amp circuit)
12 Last »
  1. #1
    irishape irishape is offline
    I have assembled this amplifer from a pcb I obtained on the internet. When I power up the R4 risistor gets very hot within 2 seconds. The instructions tell me that if the amp oscillates to change C2 from 220pf to 470pf to keep output transistors from getting hot. Is it reasonable to think that this may be my problem with the resistor which is a 100ohm resistor. I am doing this project just for learning but hate to remove something that is not the problem. In my inexperianced opinion I would suspect another reason. Any suggestions?
  2. #2
    House0Fwax House0Fwax is offline
    You say it is a '100ohm resistor', the schematic calls for a 1K (1000 ohm) resistor.
    0
  3. Thread Starter #3
    You are right, it is a 1k resistor. I have been looking at too many numbers lately. That is to say it has a 1k resistor on the board.
    0
  4. #4
    KeepItSimpleStupid KeepItSimpleStupid is offline
    Make sure Q13 and Q14 are installed correctly.
    For power up purposes short the collector to Emitter on Q12. What DC offset do you measure at the speaker terminals?
    0
  5. Thread Starter #5
    OK, shorted Q12 but R4 resistor gets hot instantly so can not measure speaker output without damage to board.
    0
  6. #6
    alec_t alec_t is offline
    If R3, Q13 and Q14 are correctly wired and functional then the maximum current through R4 will be ~2.5mA and it won't even get warm. So, I agree with KISS. Double-check the pin-out and soldering of Q13 and Q14, and the value of R3. Check too that the pcb track layout around those components actually is consistent with the schematic (it's not unknown for pcbs to have layout errors).
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  7. Thread Starter #7
    OK guys, I have checked R3 Q13 Q14, even removed them to make sure of proper type. Every thing checks. Went ahead and checked all resistors and transistors. All I have now is to check all tracks in board to make sure they all go where they are supposed to. Being new at this it will take awhile. There are no solder strings or any thing like that. Whatever it is it acts like a dead short because R4 is hot instantly yet it never blows a fuse on either rail. Anyhow I appreciate your help very much so thank you until your better paid. IA
    0
  8. #8
    ronv ronv is online now
    only a guess but the transistors may be in backwards. Google a datasheet and make sure which view of the pins you used.
    0
  9. Thread Starter #9
    Thanks ronv but I have already checked to make sure that npn and pnp are in proper place and the board has pattern as to which way they face. IA
    0
  10. #10
    Not all transistors face the same way. Unless the transistor code (type) of your transistor exactly matches the transistor code that the board was originally designed for you could have the transistor pins wrongly connected. Does the board have markings 'b', 'c', 'e' next to the pattern?
    0
    Alec's First Law:-
12 Last »
Problem with H circuit for drive bipolar stepper motor vinoth General Electronics Chat 1 23rd January 2009, 10:20 AM
Still problem with 556 circuit - please help bigal_scorpio General Electronics Chat 1 20th October 2007, 06:24 PM
Problem with PFC circuit alisarhangpour General Electronics Chat 0 1st October 2007, 12:36 PM
Problem with Flip-Flop latching circuit apakhira Electronic Projects Design/Ideas/Reviews 28 28th December 2005, 08:28 PM
ph probe op amp circuit problem cdr General Electronics Chat 7 9th June 2004, 02:12 AM
Page Time: 0.07998 seconds      Memory: 7,673 KB      Queries: 17      Templates: 0
