Where can I find 5-pin connectors?
12 Last »
  1. #1
    shosh shosh is offline
    Is there a place i can find a 5-pin connector? Ones with female sockets. I'd need an entire cable too plug into some headers.
    The type that would connect to a header on a pcb board. I need them at 100 mil spacing.
    And wonder what the proper term for the part is. I just usually call them connectors.
    any good ideas how I can attach this to a breadboard?
  2. #2
    davenn davenn is offline
    Well you are going to need to solder a ribbon cable to the terminal points on the LCD panel ... Unless you are going to mount the panel more directly to the main board??
    Check through Mouser, Element14( Farnell ) RS components. Etc and choose a connector suitable to your needs
    The are many many to choose from
    Dave
    0
  3. #3
    jpanhalt jpanhalt is offline
    Re:LCD
    First confirm whether it is 100 mil (0.1 ") or 2 mm pin spacing. Mine was 2 mm.
    I soldered a pin header to the LCD and then used a ribbon cable to another pin header in my breadboard. Regular pinheaders work, but you may want to get ones that have longer pins for the breadboard.
    Now, how do you go from 2 mm to 2.54 mm (100 mil) spacing? Mini-hard drives, like used in notebooks, have 2mm spacing. My local PC store had adapters for plugging those into regular pin connectors. I salvaged mine from an obsolete device. Pre-made cables will have two-row connectors. So, the final configuration was:
    1) 2mm pinheader soldered to LCD (20 pins)
    2) 2mm to 2.54mm (0.1") adapter for hard-drive
    3) 40 pin ribbon cable -- one position may be keyed. Use the row of 20 that is not plugged.
    4) 2.54mm pinheader in breadboard
    John
    +1
  4. #4
    AlainB AlainB is online now
    This is what I use. Note that on the first picture the 2 modules may not be aligned properly. I did not work on that for a long time and I would need to refresh my memory.
    If needed, the pins can be moved inside the plastic holder before soldering to make a good contact with the breadboard. (second picture)
    0
  5. Thread Starter #5
    What about the ribbon cables to connect to the headers? Where am I able to find those? I need to be able to connect a decade switch to a breadboard somehow
    Quote Originally Posted by AlainB View Post
    are you able to break off some of the pins on the header? My LCD has 16 contacts and I usually see 20 pin headers
    0
  6. Thread Starter #6
    0
  7. #7
    Yes, you cut easily the number of pins that you need.
    +1
  8. Thread Starter #8
    5 pin ribbon wires? anyone know where i can find those? or possibly a company that makes them?
    0
  9. #9
    Please fill in your location. It impossible to give you practical suggestions on where to find something without that information.
    Nevertheless, here are some links so you can see the sort of connectors/cables/jumpers that are available:
    http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
    http://www.ebay.com/itm/5-Pin-Male-t...#ht_952wt_1037
    John
    +1
  10. Thread Starter #10
    thats it, thats what i needed.
    couldnt find it on jameco or digikey. probably because I didn't know the correct search terminology for these cables.
    Is there a company that can custom make these cables for you? I swear I've heard of one.
    0
12 Last »
Where can I find a TSOP Adapter? pandaemonium General Electronics Chat 2 21st July 2004, 11:44 PM
Does anybody know where can I find a schematic for a R/C... Tha_Wizard Electronic Projects Design/Ideas/Reviews 4 21st January 2004, 07:16 PM
Where can i find PIR specification? masonchong80 General Electronics Chat 2 13th November 2003, 12:46 AM
Where can I find a hex inverter? saidias Electronic Projects Design/Ideas/Reviews 2 29th August 2003, 04:31 AM
Where can I find LM555CT 555 timers circuit boards at. bluetriforce Electronic Projects Design/Ideas/Reviews 2 18th July 2003, 01:45 AM
Page Time: 0.08160 seconds      Memory: 7,708 KB      Queries: 17      Templates: 0
