Hi Folks, Just looking at Time Constant of Capacitors. T = RC Easy enough, change R or C and change T but... What is the effect of voltage? I've looked at several sources and I don't see any mention of it. Thanks, Jay | |
| | #2 | |
The charging time is based on the time it takes to reach a certain percentage of the supply voltage - from memory I seem to recall it was something like 60%?. To fully charge the capacitor takes about 5T. So with a 10V supply it will take T seconds to reach 6V, with a 100V supply it will take T seconds to reach 60V. | ||
how does one do this calculation? T, is that in seconds? R, in ohms? C, in picofarads? Obviously this is not right cuz 100ohms X 1000pf=100,000 seconds. this i know is not true :lol:
| | #4 | |
It's in farads - the basic formulas usually use the basic values, ohms, volts, amps, farads, henries. | ||
R*C give you the time to 63% of full charge or one T period and as Nigel said 5T is 99% of voltage since a capacitor can (theoretically) never reach the applied voltage and also your maths is wrong 100R * 1000pF = 100ns for one time period which seems very reasonable for that size cap or 500e-9s to be fully charged | |
| | #6 | |
| | #7 | |
so if u take ur result (T) and multiply it by 5, thats how long it will take the cap to reach full capacity? (or 99%) So why the 63%? of what use is that? thanx, ive been speculating @ this 4 a wile
__________________ I'm no electronics god, i just talk too much. | ||
| | #8 |
It has to do with the natural exponential function e^x which governs some functions in nature (decay of radioactive material, loss of heat in a body etc.)and also the charge and discharge rate of capacitors. Just to show where the 63% comes from: So e^1 = 2.72, take the reciprocal you get 0.37, which gives a remainder of 0.63 from 1. multiply by 100% = 63% The typical formula will be in the form- V(capacitor) = E(1 - e^-t/RC) Interestingly e^x is also the ONLY mathematical function which when differentiated or integrated will give the exact function again! | |
| | #9 |
dont forget zero
| | #10 |
As far as I know, zero is not a function | |
| | #11 |
that may be the case, but the number zero is a special case anyway (as is infinity) also int(e^x,y) gives you y*e^x + C | |
| | #12 | |
Put differently "The exponential function e^x is a special function in that it's the only function (up to a scalar multiple) that is the derivative of itself" or as described on this link http://homepage.mac.com/nshoffner/ns...Ch4DExpFcn.htm Quote "While doing so, you will sort of 'stumble' upon one of the most profound items in all of mathematics; that is the fact that the derivative of e^x is equal to itself. This is the only function with this property (except for the trivial function f(x) = 0)," Also note that it states the case of, the result of the function f(x) = zero http://www.ies.co.jp/math/java/calc/dif_e/dif_e.html gives a nice interactive illustration for this | ||
| | #13 |
trivial function or not it is another example of a fn that int,diff is equal to itself. However where f(x) = 0 has one extra proporty over e^x (and the point that I was making) the integral of zero w.r.t. ANY variable is zero the derivative of zero w.r.t. ANY variable is zero the integral of e^x is only equal to e^x if it is done w.r.t. "x" if it is done against any other variable then it is just e^x multiplied by that variable and not e^x the derivetive of e^x is only equal to e^x if it is done w.r.t "x" if it is done against any other variable then it is always zero. My point was just that declaring an integration/differation without no dimention to do it against is meaningless. anyway a trivial solution is still a solution, sayin there is only one solution is not the solution. As an engineer you can appreciate finding the simplest solution to a problem I mean you did blast me down with what you call the "trivial" solution, let's just call this revenge ![]() call it quits, both of us know what we are talking about, both of us were right, I was just more right | |
| | #14 |
Styx No hard feelings I think it was healthy and in good spirit, also to the benefit of other members.You being more right, oh well lets leave it there.... Engineer??...I hi-jack my dad's pc when he's not at his desk :lol:, I have to go, hear him coming back! | |
| | #15 |
I realized answer right after I sent the question. But on the other hand the circuit was a relaxation oscillator, with a neon lamp. So increasing the voltage has the effect of decreasing the resistance and increasing the rate of flashing. The cap fills up faster. I assume in filter circuits the voltage is held constant, so the variables are just C and R. jay | |
| constant, time |
