Toroidal transformer
12 Last »
  1. #1
    irishape irishape is offline
    I am making up a power supply for an amplifier I intend to make. I thought I would use an toroidal tran. It is a 230/115, 160va, 48v on secondary to be used in a parallel form so as to get two 24v leads. It will be parallel on the primary also which will use the 115v supply. My question is where do I get the neg. for the secondary as four of the secondary wires are jumped so as to use the parallel circuit. I have used a regular tran. that was center tapped and the central wire being neg. made it easy. On the sec. of this tran. it has four wires , black, orange, red and yellow. Bk. to Or and Red to Yel. gives me the two 24v leads. Help on the neg.? Thanks, IA
  2. #2
    audioguru audioguru is online now
    Are you using the 24VAC to make a rectified and filtered +32VDC and 0VDC? Then there is no negative voltage.
    Maybe your center-tapped transformer also made a rectified and filtered positive DC voltage and 0VDC with no negative voltage.
    0
  3. #3
    shortbus= shortbus= is offline
    Your transformer data sheet will tell you the color code for the wires. I don't know that there is a standard for the color code, so check the makers data sheet. But to answer your question about the center tap, you connect the wires of the right color together for a center tap.
    0
    Everyone is entitled to their own opinion but not their own facts
  4. #4
    4pyros 4pyros is offline
    Quote Originally Posted by irishape View Post
    You use a 4 diode full wave bridge rectifier to get your negative. Like this;
    The four-diode rectifier circuit shown to the right serves very nicely to provide full-wave rectification of the ac output of a single transformer winding. The diamond configuration of the four diodes is the same as the resistor configuration in a Wheatstone Bridge. In fact, any set of components in this configuration is identified as some sort of bridge, and this rectifier circuit is similarly known as a bridge rectifier.
    0
  5. Thread Starter #5
    I am using a bridge rectifier to obtain the dc v. Your explanation sets me on the right track and I thank you gentlemen for the help. IA
    0
  6. #6
    Reloadron Reloadron is offline
    It sounded to me like you were looking to make a + / - supply using your transformer. This would go better if you better explained exactly what you want the output to be and had a link to the transformer data sheet.
    While the color scheme is not the same note the dots on the attached images, if you want a dual + / - supply it would be wired per the attached last image. This assumes you want a dual supply, if not the previous schematics are what you want.
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  7. Thread Starter #7
    Ron, I have been trying to upload a page of the tran I am using but am not good at this either. But according to triads wiring it can't be done the way your last schematic shows. I do want two 24v +/- alright but they show the wiring as being jumped from blk. to Or. and red to yrl. leaving you with the two ac leads to go to the rectifier but no neg. It can be wired either series or parallel and of coarse I want parallel
    0
  8. #8
    ronsimpson ronsimpson is offline
    It is OK to have the primary in parallel and the secondary in series.
    0
  9. Thread Starter #9
    OK, it finally sunk in. I didn't know you could use series like that. It goes along with a lot of other stuff I don't know. Thanks a lot for the help. IA
    0
  10. #10
    I didn't know that you are making a plus and minus power supply because you said you were connecting the secondaries in parallel.
    In series, their connection forms a center-tap.
    0
12 Last »
Toroidal Transformer marvz Electronic Projects Design/Ideas/Reviews 15 17th December 2008, 01:40 PM
Homemade Toroidal Transformer abbarue Electronic Projects Design/Ideas/Reviews 12 16th August 2008, 04:29 AM
Toroidal Transformer Fitting angie1199 Electronic Projects Design/Ideas/Reviews 3 12th August 2006, 11:18 AM
Toroidal transformer monkeytree General Electronics Chat 3 24th August 2005, 09:22 AM
Toroidal Transformer rebottex Electronic Projects Design/Ideas/Reviews 1 16th July 2003, 11:16 AM
Page Time: 0.11396 seconds      Memory: 7,716 KB      Queries: 17      Templates: 0
