+/-33V outputs - What opamp could I use?
  1. #1
    atferrari atferrari is offline
    I wonder if is it possible to do something similar to what is proposed here
    PWM Signal to LM317 to adjust Voltage Output
    but this time to get two control signals: one from 0 to +33V to control an LM317 and another from 0 to -33V to control an LM337.
    I imagine two separate opamps, one powered between 0 and +38V and the other between -38V and 0V. (I have those +/-38V DC available from an old power supply).
    What could be the most suitable opamps?
    Searching through Farnell I can at least compare some but the prices of the suitable(?) ones is scary. To come to my hands I have to think of them multiplied around 4 times!!
    Maybe I am overlooking something...
    Any suggestions? Gracias
    Agustín Tomás
    In theory, there is no difference between theory and practice. In practice, however, there is.
  2. #2
    MrAl MrAl is online now
    You think you could post a schematic rather than have us search through a bunch of posts to see what you actually want to do? I think this would help a lot for people reading this thread. I know it would help me to understand you better.
    0
    One test is worth a thousand expert opinions, but one expert specification is worth a thousand tests.
    If i miss something you posted or something you think is important, feel free to PM me.
  3. #3
    alec_t alec_t is online now
    If I understand you correctly you want one PWM signal to give two simultaneous outputs; one of them negative (0 to -33) and the other positive (0 to 33) ?
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  4. Thread Starter #4
    Here it is
    I believed it was better to read about the idea until reaching the circuit. But OK, that is me.
    Here it is
    Two independent PWM signals; each one controlling one regulator. That is why I think of having them powered between common and its respective rail (single supply).
    My concern is the type (and COST) of the opamps I could use.
    0
    Agustín Tomás
  5. #5
    The op-amps themselves aren't critical as they don't have to withstand 33V. You could run them at, say, 12V and use them to drive BJTs or FETs switching loads operating from 33V.
    0
    Alec's First Law:-
  6. #6
    ronsimpson ronsimpson is offline
    High voltage op amps are not so common but:
    AD8274
    ADA4004
    LTC6104, LTC6103, LT1013
    AD5749
    OP4177
    PA340CC
    PA341CE
    0
  7. #7
    Perhaps this? Almost any opamp (I used a LM324 model) with rail to rail input will do. Not having a LM317 or LM337 model I used LT1085 and LT3015 respectively. There are two 0V to +5V PWM inputs (from a micro). One opamp has a 5V supply, the other a -5V supply. The regulators have +33V and -33V supplies respectively.
    0
    Alec's First Law:-
  8. Thread Starter #8
    Will try it.
    Busy with vessels right now but I will try it.
    Gracias.
    0
    Agustín Tomás
what could i use a Universal mono pre amplifier for? p88prw General Electronics Chat 5 13th June 2010, 06:23 PM
What relay could i use? dramrattan Electronic Projects Design/Ideas/Reviews 12 26th February 2009, 10:12 AM
what translator should i use? crysrose Datasheets, Manuals or Parts 2 16th January 2004, 01:52 PM
need adv. on what cpu controler to use ??? qbsystems Microcontrollers 2 2nd January 2004, 07:25 PM
Robotic Hand, what could I use? WaRFiElD Robotics & Mechatronics 4 29th September 2003, 04:03 AM
Page Time: 0.10228 seconds      Memory: 7,609 KB      Queries: 17      Templates: 0
