Do you have a data sheet or part number for the flashing LEDs?
I wanted to wire up a bunch of cheap multiple flashing LEDs (red-yellow-off, 3 seconds total cycle time) that I got off eBay but they aren't playing nice. If I run just 1 LED they work fine but if I put 2 or more in parallel (each with its own resistor), they start misbehaving and flashing only red (for about 1/10th of a second) then off. it did not matter if I used resistor on anode or cathode side. I am just guessing but these flashing LEDs seems noisy and causing interference? It'd seem silly (and messy) if I have to add 100 capacitors parallel to each LEDs just to cancel out each other's interference.
Is there a way to wire up some 100 of these as I wanted to put it inside my computer and make it look like that old computer with lots of flashing lights from old sci-fi show. (More specifically I wanted the WOPR display LED from the movie War Games)
Available rail are 12v and 5v. As a last resort, I could also use 2 resistors one on each side of LED with a cap parallel across LED.
There is no datasheet with details, just some basic information:
Code :Size (mm) 5mm Lens Colour Water Clear Forward Voltage (V) < = 3.6 Reverse Current (uA) < = 30 Luminous Intensity Typ Iv (mcd) 6000 - 7000 Life Rating 100,000 Hours Viewing Angle 20 Degree Absolute Maximum Ratings ( Ta = 25°C ) Max Power Dissipation PM = 80 mw Max Continuous Forward Current IFM = 30 mA Max Peak Forward Current IFP =75 mA Reverse Voltage 5 ~ 6 V Lead Soldering Temperature 240 ° C ( < 5 Sec ) Operating Temperature Range - 25 ° C ~ + 85 ° C Preservative Temperature Range - 30 ° C ~ + 100 ° C
I've contacted the seller to see if he can provide more.
I am looking for how they think it should be powered.
The LED is not just a LED it includes a IC inside.
I have used a multi-colored LED blinker that goes through 32 colors. It will take hours to find the data sheet. We are using it in production. I have not thought about it in 2 years. I think it can not be used like you are using it. It sounds like the IC is being reset after its first step.
Your part likely is not what I am using. But sounds like a line of similar parts. I will try to find more information. And you will try to get information.
Is this what you have?
It is probably similar but I can't tell without opening the LED and putting it under microscope to see and it's pretty dang hard to open up a LED.
Still, would a capacitor help? I have some SMD caps (0.01uF) and solder it between the legs of the LED.
Cant hurt to try.Still, would a capacitor help? I have some SMD caps (0.01uF) and solder it between the legs of the LED.
You could also try putting a respective ordinary silicon diode (forward biased) in series with the dropper resistor of each LED. So you have +V /\/\/\/ >¦- LED. That should isolate each LED from its neighbours.
My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
Alec's First Law:-
Every problem has a solution (given the right information and resources).
Try the capacitor across the LED. The ones I use draw very different current depending on where in the cycle they are.
The power supply is not described. It must have a steady output voltage to power flashing LEDs so that they don't cause the voltage to bounce up and down and affect each other. Is the power supply a weak little battery?
Try adding a 100uF or 1000uF capacitor parallel with the power terminals near the LEDs and resistors. 0.01uf will be useless.
I hope the LEDs with their series resistors are really in parallel and not actually a few flashing LEDs in series.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| pic 12c508 flashing led | billyboy | Microcontrollers | 11 | 7th March 2008, 11:05 AM |
| Flashing LED in a drumstick? | grrr_arrghh | General Electronics Chat | 26 | 26th May 2004, 11:55 AM |
| flashing LED | 1997 GA16DE | General Electronics Chat | 11 | 29th February 2004, 05:52 PM |
| PIC output signal not a nice square wave | ChrisBennet | Microcontrollers | 4 | 26th February 2004, 11:51 PM |
| Flashing LED project | johnk | General Electronics Chat | 10 | 21st May 2003, 02:29 AM |
