Need help in SCR power control circuit
12 Last »
  1. #1
    dummy55555 dummy55555 is offline
    HI, I am building a single phase full wave controlled rectification circuit. The concept is to control the output voltage by controlling the firing angle of thyristor. I am building a circuit from this webiste: http://multyremotes.com/ac-motor-speed-control.htm
    There are 2 main circuit which is zero crossing detector circuit and firing angle control circuit.
    Since this project output is a AC. So I had modify the circuit output to become a DC.
    But I am not sure whether the circuit is correct or not. So hope guru and senior here can help me check it out. If wrong please guide me. thank you.
    The attachment picture is mine modified circuit.
    Still got 1 more question, This project he used an Atmel microcontroller, but if I change to PIC microcontroller should be no problem right???
    Thank you
  2. #2
    MrAl MrAl is offline
    1. You might need a resistor in series with the output of the opto to limit current through the opto and the gate.
    2. Is that a DC meter there? You'd need a resistor across the meter to act as a decent load for the SCR or you may end up measuring the voltage due to the leakage of the SCR as well as the voltage when it is turned on.
    3. Might also need a resistor across the output of the bridge rectifier to make sure the output goes close to zero volts so the SCR can turn off when required.
    4. For better control you might be better off connecting the SCR in the ground lead of the bridge rectifier instead of the positive lead. This allows for better on/off control of the SCR, with the SCR cathode connected to ground.
    +1
    One test is worth a thousand expert opinions, but one expert specification is worth a thousand tests.
  3. #3
    Thanks for suggestion. I Had made some changes based on your suggestion, please have a look.
    And because I want a variable DC output voltage, so I has use a DC motor as a load for demonstration, the motor spin faster when higher voltage.
    Please help me check out this circuit, If no problem I am gonna to start the coding ^^.c2.jpg
    0
  4. #4
    Actually you should connect the SCR between the bottom lead of the motor and ground.
    Also, since you are using a controller to drive it you can make the drive pulse short. You'll have to check the specs on the SCR you are using though to find out what the pulse width should be and also the minimum drive current to the gate. The shorter pulse width keeps the gate dissipation down.
    It's also wise to connect a resistor from the gate to ground. Usually 1k should be good, but remember that the other resistor has to be able to drive the gate up to the required voltage as well as supply the required gate current too.
    +1
  5. #5
    For the minimum current and voltage to trigger the gate I had found on some datasheet which is here..
    This is the picture that highlighted.
    But for the pulse width isn't it I have determine the time to trigger the gate and off the pulse?? something like delay???
    Sorry if i am wrong ^^
    0
  6. #6
    Oh ok, well you seem to be working with a very hefty SCR there, which would have a decent max average gate power rating too. That means you can probably drive it with 200ma continuous and not worry about the pulse duration. That should ensure turn on every time.
    Usually the gate power is more important because the SCR packages are smaller. This one is quite a big one :-)
    When will you be ready to test this?
    +1
  7. #7
    haha.. oic.. I am still not quite sure yet what kind of SCR I am going to use yet.
    I am going to test it out after I had develop the code for the microcontroller.
    I am planning to test this circuit using proteus software first before building the entire circuit out.
    I am planning to use pic18f4520 as the microcontroller, but this circuit use an Atmel chip and don't really understand the code.
    http://multyremotes.com/ac-motor-program.htm
    Can you help me explain some of it. I don't really understand those code really well.
    U don't need to explain line by line, but just the concept on how the entire code is running.
    Basically this is what I understand from the code but not really sure right or wrong.
    Steps:
    1. Enter the time delays
    2. Make a interrupt when there is zero crossing detected.
    3. In the interrupt program, read the time delay inserted,
    4. delay the specific time and on the give a pulse to the SCR.
    5. On the next interrupt, the pulse is off and repeat step 3 and 4.
    Thank you.
    0
  8. #8
    It sounds like you have the basics there already.
    I would think you would trigger each half cycle though, so for any zero crossing (0 degrees or 180 degrees) you would do the very same thing, unless you only want half wave output. Full wave is better though.
    The delay the uC waits is the half cycle time minus the required 'on' time.
    It's also a good idea to build in some sort of 'over delay' protection, if you intend to fire at small conduction angles. This helps protect against accidentally triggering a bit too late, which instead of a small conduction angle (and small output voltage) you'd get a large conduction angle (and very high output voltage) which would defeat the required time delay setting.
    Also, if you are using a positive trigger pulse you have to watch out what triac you pick. The triac you pick has to support a positive trigger with both polarities of MT1 and MT2. Some dont support both polarities with a positive trigger pulse, but most do with a negative trigger pulse.
    +1
  9. #9
    Yea. I am going to do a full wave output.
    But I do not have any idea on how to do the "over delay" protection. Can you provide some ideas??
    Beside that, I think I am going to use a thyristor as the SCR. Because what mine lecturer taught me is that a triac normally used to control AC output.
    Please correct me if I am wrong. (and may be mine lecturer is wrong too ^^)
    One more things is that I am not really understand MT1 annd MT2. Can you please explain a bit about it??
    Thank you ^^
    0
  10. #10
    paulrusu paulrusu is offline
    mt1 mt2
    I would be interested in info about MT1 and MT2 as well.
    0
12 Last »
Need help on Radio remote control circuit(transmmiter&reciever) awaismqsd Electronic Projects Design/Ideas/Reviews 26 5th February 2009, 12:50 PM
Need help in IR Remote Control Circuit fire88 Electronic Projects Design/Ideas/Reviews 7 23rd December 2008, 07:38 PM
Please help, Power control circuit? yeonatan General Electronics Chat 4 2nd June 2007, 03:48 PM
I need help switch mode power circuit darkstorm General Electronics Chat 1 1st March 2005, 07:28 AM
Need help in building an alarm circuit Danny1019 Electronic Projects Design/Ideas/Reviews 3 15th July 2003, 07:33 PM
Page Time: 0.06552 seconds      Memory: 7,302 KB      Queries: 17      Templates: 0
