The core became a magnet
12 Last »
  1. #1
    atferrari atferrari is offline
    To experiment in repelling a magnet I winded a 3-layers inductor around a piece of a common nail (soft-iron?)
    Initially it seemed to work OK but later I found that, after cutting the current, the magnet was atracted by the core which started to behave as a magnet. Not what I wanted, precisely.
    Just to be sure I verified that a paper clip is attracted by the core.
    I did not foreseen that. How to avoid it? Not using a core? Or is this the wrong material?
    Now that I think of it this would be good if I wanted to attract the magnet. But I want just the opposite.
    Agustín Tomás
    In theory, there is no difference between theory and practice. In practice, however, there is.
  2. #2
    colin55 colin55 is offline
    The nail is steel - not iron.
    0
  3. Thread Starter #3
    Hola Colin,
    If so, what could be a good material (that I could find easily around) serving as a core and not being converted into a magnet?
    I am afraid that there is no any and I will have to build a really big solenoid.
    0
    Agustín Tomás
  4. #4
    Nigel Goodwin Nigel Goodwin is offline
    Super Moderator
    Quote Originally Posted by atferrari View Post
    It's not 'soft' - to use a nail in this way (a common school experiment) you need to 'soften' it - simply heat it until red hot, then let it slowly cool down, this will 'soften' it.
    I did this with my daughter when she was at primary school
    0
  5. Thread Starter #5
    Hola Nigel.
    After softening them like that, should I still expect some residual magnetism after use?
    Not able to try it right now.
    0
    Agustín Tomás
  6. #6
    MrAl MrAl is offline
    To reduce the stored field of a material you do what is normally referred to as degaussing. This involves using an AC generated field that slowly decreases to excite the object to be demagnetized. As the AC field takes the object through its hysteresis loop and slowly decreases it takes the objects field with it and it becomes demagnetized.
    0
    One test is worth a thousand expert opinions, but one expert specification is worth a thousand tests.
    If i miss something you posted or something you think is important, feel free to PM me.
  7. #7
    Use a ferrite rod from the aerial coil of a transistor radio
    0
  8. #8
    Super Moderator
    Very little.
    0
  9. #9
    Super Moderator
    Quote Originally Posted by colin55 View Post
    Will that work as a core for an electro magnet? - I've never tried it, or heard of anyone who has.
    0
  10. #10
    He has asked for a material that will not have or produce any residual magnetism. A nail is steel and has a completely different magnetic dipole structure than Stalloy or other magnetic material used for DC electromagnets. Annealing a nail does not make it "soft iron." It simply anneals it.
    0
12 Last »
The Breadboard ElectroMaster Electronic Theory 22 15th October 2008, 01:51 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008, 01:45 PM
Where to get the core of a 25W wire wound resistor mazur50 General Electronics Chat 9 18th December 2007, 11:28 PM
help regarding the datasheet for 8031 oscillator layolapanju Datasheets, Manuals or Parts 5 10th September 2004, 05:45 AM
any body have the uc/os core file? mikemikemike Electronic Projects Design/Ideas/Reviews 1 10th October 2003, 10:41 AM
Page Time: 0.08853 seconds      Memory: 7,676 KB      Queries: 16      Templates: 0
