SDRAM problem
  1. #1
    Jane11 Jane11 is offline
    SDRAM problem
    From time to time I must repair an equipment that has its own BIOS, CPU and SDRAM
    This SDRAM has 256MB together and consists of 4 SDRAM modules(IC).
    Sometimes equipment does not work.Then there are several possibilities for that.
    Faulty CPU or BIOS or SDRAM.
    Is there a method how I can find out that SDRAM is faulty? If so which module of those 4 SDRAM modules might be faulty?
    Each SDRAM module has 66-pin Plastic TSOP(II) and is soldered on PCB.
    or what method shall I use to check that the processor sends signal( e.g. address signal) to SDRAM?
    Thank you for help
  2. #2
    lebevti lebevti is offline
    you would have to determine the address range that each SDRAM covers
    then, if you have some kind of resident monitor or OS, you try writing and reading from addresses within each chip's range...whichever one comes back with an error or doesn't write correctly would be the faulty chip
    0
  3. #3
    4pyros 4pyros is offline
    Dose it have an OS?
    0
  4. Thread Starter #4
    It has Linux, but it is embeded Linux.It has BIOS and if SDRAM is faulty it does NOT start at ALL
    0
  5. #5
    Look up the BIOS and see if it has a RAM test.
    0
  6. Thread Starter #6
    How can I have a look at the BIOS?
    It is Linux embeded device. No choice for such RAM test
    0
mains adapter problem norvica General Electronics Chat 5 7th October 2008, 11:47 AM
problem of programming pic16f84a Byron Yau Microcontrollers 15 19th April 2003, 05:10 PM
problem in smulaiting (8086) using orcad 9.2 massoti General Electronics Chat 16 23rd February 2003, 04:53 PM
Transistor problem Solid Snake General Electronics Chat 4 10th January 2003, 07:24 AM
How to diagnose a problem Weasel General Electronics Chat 1 1st January 2003, 03:40 AM
Page Time: 0.07747 seconds      Memory: 7,568 KB      Queries: 16      Templates: 0
