US electrical equipment (Soldering station) in the UK
  1. #1
    LukeeeeBennett LukeeeeBennett is offline
    I'm purchasing a new soldering station, but I can only find US 110v version with the US plugs. Can I just use an adapter? Should I use a transformer + adapter? Can I even use it?
    Thanks.
  2. #2
    Reloadron Reloadron is offline
    Use a transformer as in actual transformer. Do not use one of those universal inverters or any sort of inverter. Just a simple 240 / 120 transformer is all you need. Sine in and sine out. That should work fine for you. Just make sure the VA rating exceeds the total power needed for the solder station.
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  3. #3
    ARandomOWl ARandomOWl is offline
    Check the input voltage range of the unit. Many will allow 110-230V input. If that's the case, you just need the appropriate cable, no transformer required.
    0
  4. #4
    JimB JimB is offline
    Quote Originally Posted by LukeeeeBennett View Post
    Thanks.
    At the risk of stating the blindingly obvious, why did you not purchase a soldering station which was made for the UK market? Such things are readily available.
    An adapter just gives a different pin configuration to the plug. Most of them are poorly made, have bad contacts and are an accident waiting to happen.
    You can of course just cut off the moulded USA plug and wire on a standard UK plug, that is what most sensible technical people would do.
    However if the soldering station will only work on 120volts, you will need a transformer, which will be expensive.
    So, if you are lucky it will have a dual voltage rating, if not you will need a transformer.
    Either way, why did you not just by the correct item in the first place?
    As a modifier to my signature line:
    Experience is directly proportional to the amount of money wasted.
An inexpensive yet quality soldering station HiTech General Electronics Chat 13 1st May 2007, 12:14 AM
do you think a soldering station worths it? patroclus General Electronics Chat 4 30th March 2006, 07:29 AM
Does anyone know about this soldering station?? patroclus General Electronics Chat 10 4th October 2005, 08:49 PM
Need input: Custom made soldering station! Jay.slovak Electronic Projects Design/Ideas/Reviews 25 5th September 2005, 04:52 AM
Soldering Station Confusion TekNoir General Electronics Chat 16 1st May 2005, 04:49 AM
Page Time: 0.04484 seconds      Memory: 7,305 KB      Queries: 16      Templates: 0
