Hi Guys,
Just a follow on question. Since I have never rectified mains AC without a transformer I am not sure how to go about it. After the transformer and rectifier I usually have a smooting cap and usually a decoupler too.
With such high voltage and a load approaching .5kW I am worried about getting things right first time so if anyone can push me in the right direction as to the needs of the motor and the best smoothing values (if needed) I would be a lot more secure.
Al
I am an insomniac, but I don't lose sleep over it!
Listen well to cachehiker ! Shaft/bearing currents can be a real problem when using high frequency PWM drives. I am currently replacing bearings every 3 months on my furnace fan motor.
pilko
Hi Guys,
Pilko, if I ever get the sander working it should only get a few hours use per year! Unless I start cutting things too big on a more regular basis. hehehe
Seriously it would only be used maybe a few minutes at a time, it is only for fine tolerance stuff where the belt sander is too harsh.
But I do need advice on the switching guys.
Happy Holidays Al
"I am an insomniac, but I don't lose sleep over it!" ---- LOL Love it
I'd be embarking on a quest to find a better fan motor.
There is simply such a thing as motors that have been optimized (cost reduced) for strictly pure DC or 50/60Hz AC applications. Bearings in such motors will simply not stand up to use with inverter/PWM drives when the motor frame is grounded. There are times when even isolated mounts and shaft grounding brushes aren't enough.
The biggest thing to remember about rectified line voltages is both supply rails end up hot. With 230VAC, the positive one will settle in at +160VDC relative to ground and the negative one at -160VDC. The processor will likely share its negative supply rail with the rectified line. Pushbuttons, displays, potentiometers, and such that are connected to the processor will be shock hazards unless they're optically or otherwise isolated. Disconnecting the processor from the mains for a while (depends on how fast it discharges) before connecting it to the USB port or your computer for programming is MANDATORY unless you have and abundance of computers at your disposal. Connecting a grounded computer to a hot rail will let the magic smoke out. You might be able to salvage some drives or some memory, but the motherboard will likely be roached. This makes debugging a major pain so concentrate on writing robust or easily testable code the first time.
Thanks cachehiker,
I am starting a new thread so as not to hijack this one. --title "Motor Shaft Currents".
pilko
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| What is the best C Compiler for PIC16F877A? | dimastar85 | Microcontrollers | 14 | 23rd December 2006, 10:21 PM |
| what is the best 'noob' microcontroller? | JPulham | General Electronics Chat | 7 | 23rd July 2006, 02:04 PM |
| The BEST method? | mstechca | General Electronics Chat | 2 | 24th September 2005, 01:54 PM |
| What's the best way to defeat surveilance ? | Nostrafus | Electronic Projects Design/Ideas/Reviews | 54 | 27th September 2004, 09:27 PM |
| What is the best idea for a broken Karaoke Machine? | reverend Boltron | Electronic Projects Design/Ideas/Reviews | 3 | 19th September 2004, 09:09 AM |
