Originally Posted by fabbie According to the website you provided, http://www.iitk.ac.in/eclub/Circuit/l298.htm
It said here that the current sensing here will control the current according to VS/R and will be provided to the load.
If the Vs is 12V. wouldnt the current be EXTREMELY big? 120Amp.
Mind teaching me how u did u attain the value of 0.1ohm? |
VS isn't the supply voltage, it's the sensing voltage - the voltage dropped across the sensing resistor.
I've just had a look at the datasheet for the 298, there's no internal current limiting at all - it just provides a connection pin from the bottom of the H-Bridge to ground. By inserting your own resistor in there you can monitor the motor current, and do whatever you want with it.
By using a 0.1 ohm you would probably have to amplify the voltage to make it to a useable level.
