Old 17th November 2004, 07:51 AM   (permalink)
Default Regulating Current
I'm working on a design project where some components (ie motors) need ~1A of current. But I've also got digital stuff on it that I don't want to exceed 200mA.
I've got only one source of power, from a 12V lead acid battery at 1.35A (ripped it off of an electric scooter).
I've got a 7805, connected directly to the battery to to drive the digital stuff. (The 7805 is getting kind of hot, I'm considering getting a 7809, and then connect the 7805 to it, is this a good idea?)
My question is, since the battery supplies this relatively high current, should I just connect it directly to the 7805 and drive the IC's? (I've tried it, and it works.)
My second questions is, if I do want to limit the current coming from the battery, what is a simple way to do it? ie. some chip I can just buy for the job.
Any suggestions my overall setup is also welcomed
Thanks.
fantasymick is offline
Old 17th November 2004, 09:02 AM   (permalink)
Default Re: Regulating Current
Put a decent heatsink on the 7805, it should then be fine.
A battery doesn't 'supply' a current, the load DRAWS the current, so the load will take what it needs, no more!.
If you wanted to limit the current capability of the battery you could do so, a simple resistor is a crude and simple way - but you need to have a reason to want to do this, and I don't think you do!.
Nigel Goodwin is online now
Old 17th November 2004, 11:10 AM   (permalink)
Just what are you driving with a 7805? If you've got simple digital logic perhaps you should check it; most of the time simple stuff won't draw enough current to heat up a reg unless you're driving coils, leds, etc.
Resistors are a poor form of current limiting for motors, it makes them hard to start, run slower, and run at different speeds depending on loading. There are several schemes. A good simple idea might be a self-resetting circuit breaker, they don't drop much voltage until they open up. http://www.allelectronics.com carries some polymer fuses and flat battery pack fuses that both self reset.
http://www.allelectronics.com/cgi-bi...065&type=store
http://www.allelectronics.com/cgi-bi...00S&type=store
Oznog is offline
Old 17th November 2004, 02:04 PM   (permalink)
Here is a crop from LM317 datasheet...
Sebi is offline
Old 18th November 2004, 03:29 AM   (permalink)
Thanks a lot for the comments. I think I know what I have to do now.
