Nobody???
Then, PLEASE, let me know if somebody knows the source (documentation) for LC/ESR (I think) meter - I have attached a schematic of this device - I have no other information!
Also, if somebody know the link for this meter in this forum let me know - I can't find it with search.
TIA!
! Either they are not cheap (must be DIY), or aren't precise enough or.... always some drawbacks
! Please note: I'm on a VERY limited budget!
? Well, I just start to assemble that "Hungarian" LCM3 meter! Since I am not a member of VRTP (Ruslan is friend of mine btw.) maybe I can ask you about pot-core inductor, as I know you are using pot-core inductor in your version of LCM3? So, I somehow find one such core, but I don't know how to properly "use" it? The parameters are: outer diameter = 22mm (yes, I know, is it a little big), high of two halves together (in "working state") is 16mm. No air-gap! There is a hole through inner pillars of 5mm. It is very old Siemens & Halske 57T5 T26 X09 o.L. core. I don't have any info about T26 ferrite material. So, what do you mean, can I use it? If I wind it "multi-fillar" (litz-wire) like e.g. 7-strains - should I twist them, or just keep them together in a simplest way? Is the air-gap totally necessary? What should be a minimum and maximum diameter of each thread/strain (or allowable range)?
