| In my Microelectronics course, we're learning about BJT transistor operations and calculating the current's and voltages. The textbook is about 1200 pages and weighs ~10 pounds. It would probably be more useful as a paper weight than a text book. I was wondering if anyone had any good sites or info on how to do these calculations. I had to miss a couple classes due to being slammed with tests in all my other clases. So I'm alittle behind and would greatly appreciate your help. Thank you.
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| i think you are studying from Microelectronic Circuits by Sedra/Smith, right ???? well, if thats the book you are reading i would recommend it as a pillow, seat, and everything that you can imagine of. but dont use it as a paper weight :lol: i seriously recommend this book for a microelectronics course. and if you want to do calculations then you would definately need a textbook. most of the info on the net isnt that deep that you would normally find in a good textbook. you could find a number of articles and lecture notes from various universities but a book is the best thing. i hope that helps | |
| | (permalink) | ||
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |||
if u have a particular question dont hesitate to ask
__________________ subzero... wins.. | ||
| if you want to understand the working of a BJT the article http://amasci.com/amateur/transis.html would be helpful but as i said before, for the calculations or simulations u need a good book which you already have. i could suggest a number of other books in addition to the book you have. "The Art of Electronics" has a good discussion about BJTs. another easy book is "Electronic Devices" by Floyd. you should also read the book "Analysis and Design of Analog Integrated Circuits" by Hurst, Lewis. this is of a little bit higher level but it is a great reference. a visit to the library would be a really great idea. you would find a huge amount of info on BJTs in about every electronics book. i have to tell you that you should work hard and concentrate alot on the operation of BJTs because the later courses will assume that you have perfected your knowledge of BJTs. i hope that helps | |
| I have a pretty good idea of how it works, the moving holes and electrons and what not. It's the calculations that are getting me. I can calculate the currents pretty good, using the ic=Bib ect. but it's getting the Vc Vb and Ve values. We are mainly looking at the transistors in forward active mode. Quote:
| | (permalink) | ||
actually the book that you have starts from a higher level. there are other books that give you a simple approach in calculating the voltages and currents for the common types of circuits like the base-biased amplifier, voltage-divider biased amplifier etc. i would recommend; Electronic Devices By Floyd Electronic Devices and Circuits by Bogart | |||
| how do I modify a transistor in pspice to behave like the simplified models that I'm using for my calculations?
| What's the deal with this circuit here: we are supposed to solve for Vb (in between the bases and the 10k resistor) and Ve (shown as vo) when Vi= -5 and -10V. Are the transistors in saturation mode? (atleast for the -5V case?) I remember building something similar to this in my circuits I class, we used op amps to make an audio D/A converter, and this was on the end to give enough current/power to the speaker.
| i simulated these circuits in multisim and here is what i got | |
| Sam, something is hosed in your sims. When the input is -5v, the PNP acts as an emitter follower, and the emitter voltage should be about -4.1v. The base will be at about -4.8v (both these values depend on PNP beta). When the input is -10v, the PNP saturates, and the emitter will be at about -4.9v. The base will be a Vbe drop lower, or about -5.6v. The NPN never turns on, so is not a factor in this circuit. Simulators can be very misleading - although I ran this on SwitcherCAD III and got results very close to those I predicted. Jrz126, this is a push-pull emitter follower, but it only works well for analog signals if you keep the input signal range well within the collector supply voltages (+/-5v in this case). It will have significant crossover distortion unless it is embedded in a feedback loop containing a fast slew rate op amp. As a stand-alone circuit, it is good for driving heavy loads with digital or switching inputs. | |
| :cry: this keeps getting complicated. but i dont know why i just dont want to abandon my simulator. anyway, why doesnt the NPN ever turn on ???? | |
| oh ok i forgot that the voltage at the base was more negative than the voltage at the emitter. | |
but anyhoo, when Vi is equal to -10V, would the PNP transistor be in saturation mode? If Vcb (or Vbc I cant remember which I used. but I did use the correct one for my hw.) <(-0.4V) then it is in saturation mode. IIRC my Vcb for the -5V case was -0.38V, since it was very close to -0.4, I just assumed the -10V case was in saturation (I only had 10 minutes before i had to turn it in so I couldnt double check it). I calculated my forced beta (Ic/Ib) to be 99 and the actual beta was 100 Samcheeta, thanks for your help with that. I found an example of the circuit in my pillow :lol: , so I noticed that the NPN was cut off. Is that simulator program free/any good? I think it might come in handy. Could Sam's simulation be messed up since the beta wasnt specified?
