Old 22nd April 2003, 02:55 PM   (permalink)
Default Transistor switch
Hi, I'm plaing to make a thermal switch, and i want to do it with a transistor (relays click anoyingly) but I'm not sure of what transistor I should use. The voltage throught the transistor will be about 12 volts and the current about 5 amps. Now I'm wondering if anyone could help me, will a normal biopolar (BD243) do the job or would it be better with a fet, or even a mosfet?
Thanks for any explanation!
hantto is online now
Old 22nd April 2003, 03:37 PM   (permalink)
You could use an Lm311 op amp as a comparator thermistor as your temp detecting device, with something like a 10k resistor as a pull up on the output(its an open collector op amp) and use a BUZ11 mosfet to switch with.....Does that fit the bill ?
Chippie is offline
Old 22nd April 2003, 03:45 PM   (permalink)
Yes, thanks. But I have already the temp sensing circuit ready, i only wanted info on the transistors :wink: but thanks for the help!
Old 25th April 2003, 12:54 AM   (permalink)
A BD243 will do the job, though it's only rated at 6A, so you will be getting quite close to its limit. You may want to consider something a little higher rated (eg, MJE3055 - 10A).
Using a mosfet has advantages and disadvantages. They require very little drive current (several pA into the gate), but tend to have a higher "on" resistance than bipolar transistors. However, if you are prepared to pay more, you can get MOSFETs with a low on resistance.
Phasor is offline
Old 25th April 2003, 01:09 PM   (permalink)
How about 2N3055? It is rated for 15A Ic(max.).
kinjalgp is offline
Old 25th April 2003, 09:04 PM   (permalink)
whats the difference between this just a momentary switch?
thanks,
david
daviddoria is offline
Old 26th April 2003, 02:53 AM   (permalink)
David - can you be a bit clearer? Not quite sure what you are asking...
Phasor is offline
