| Hello everyone Has anyone here had any luck with the non-mercury tilt switches? I am looking to replace a mecury in glass tilt switch, but I don't know how well the ball bearing or pendulum style switches last. The application is in a vehicle, so it will be subject to heavy vibration, and I am wondering how well the gold plated ball bearing types, or similar mechanical switches stand-up. The load is less than 1 amp, but the switch should have low on-state resistance, and not be a "one-shot" or low duty cycle design. Any suggestions or ideas greatly appreciated. ( The move away from mercury is due to WEEE / ROHS component limitations ) | |
| The one time I tried using a non-mercury tilt switch (ball style) it didn't work well at all. Poor contact; very erratic. I ended up going with a mercury switch instead, but potted the whole thing. j. | |
| how about the ADXL series .? they measure tilt. http://www.analog.com/en/cList/0,288...255F43,00.html | |
| Thanks for the response! I have had a hard time getting decent info from the various makers of alternate switches, regarding bounce, durability, etc. Like you, what I am doing now is placing a regular mercury in glass switch in a plastic 35mm film container, and filling it with silicone, then mounting the whole thing with nylon "P" clamps. I have to put a "contains mercury, dispose of properly" label on it. It works well, but kinda looks "home-made." Somewhere there must be a workable solution? I wonder what the appliance makers have done? -edit- Thanks williB, you posted while I was replying. What I am looking for is a simple, up or down type position switch. Along the lines of the sensing if the car trunk lid is opened or closed, so a light gets turned off or on. The Analog Devices IC looks interesting, but probably would involve too much support circuitry. | |
| hmm... looking at my post, I may have confused the issue a bit. What I am doing is not sensing a trunk lid, but sensing the position of some machinery on a vehicle. This machinery has 2 positions, "deployed" and "stowed," approximately 90 degrees difference in the positions. The vehicle operator cannot always see if the machine has fully reached either position while sitting in the cab. This sensor simply turns on a LED on the cab control panel to indicate the state of the equipment. The mechanisms and motors moving the equipment is self controlling, the operator just needs an indication of if things have happened or not after operating the machine. Unfortunately, using a limit switch is not possible, due to the small size of the equipment being deployed, and various mechanical limitations. Sorry for not explaining better Thanks! | |
| Do you have room for a magnetic reed switch??
__________________ gerty | |
| Or maybe a Hall switch, no moving contacts! | |
| ante, gerty: hmmm... both good ideas. There is room for either. The big issue is getting the signal from the device, without having to worry about processing it, or noise being picked up. Vehicles can be a nightmare of electrical noise. I wonder if it would be possible to "focus" the magnetic viewing angle of either one? The only drawback I can think of right off hand would be false readings caused by the motors that are moving the machinery. The hall sensor would perhaps be the easiest to focus, but the reed switch easier to deploy. Either switch could be shielded nearly all the way around, leaving only a small window for magnetic flux. The beauty of the mercury switch design was the simplicity... one side grounded or at 12VDC, the other the signal wire, so the system was basically one wire. But using the Hall or reed switch may also be a winner! Micronas HAL55x series might be good for this. A transitor as a gate could sense the current differential of the Hall device. Probably need to use shielded wire. I will have to experiment and see Thanks for the input! | |
The Hall effect switch is a good idea. A reed switch is mechanical and subject to wear and mechanical failure. Enough vibration can cause those thin reeds to contact momentarily too. | ||
| One experiment done. Test drove the reed switch ( literally. ) It's a no-go. Lots of erratic behaviour. Tried rotating it axially, pretty much the same results. Doesnt have the inertial of the mercury, so the contacts bounce together. The mercury will do this too, but not very often. You don't realize how harsh a vehicles chassis rides until you do stuff like this. :shock: It's Hall sensor test time now. Oznog: the photodetector could work mechanically, but you're right, I think keeping it clean would be hard. Too much road dirt, salt spray ( in winter ), etc. | |
| Hola! Try using a metal-can style of mercury switch. You can sometimes find them in small ceramic space heaters for anti-tip-over protection. They are rugged, self-contained (no glass envelope to break), and should be still available. Good luck!
__________________ <ckd> "Chance favors the prepared mind."--Louis Pasteur (1822 - 1895) | |
Thanks for the idea though! | ||
| Is this 90 Deg in relation to ground or gravity? Reason i'm asking is a tilt switch out of a pin ball machine would be perfect if gravity. Might even work if ground, if you don't park on real steep hills and your 90 deg does not need to be exact. | |
