Old 7th November 2004, 09:34 PM   (permalink)
did it work?
williB is offline
Old 7th November 2004, 09:39 PM   (permalink)
Hey willi! Good to hear from ya. :wink:
I am having great difficulty sourcing the relay. I was hoping someone out there might already have one and could run a test to see.
nerosrevenge is offline
Old 8th November 2004, 12:00 AM   (permalink)
Default Re: Looking for a switch...
Originally Posted by nerosrevenge
I am wondering if there is a switch out there that can acomplish the following:
I have a device powered by a 9v battery. I want to be able to depress the switch and have a set delay of 3-7 seconds. At that time the switch opens allowing current to pass. Idealy the switch should be small and in-expensive.
Any ideas??
Thanks!
I don't think we understand what you want - at least I don't.
Do you want
(1) power applied immediately when the switch is pressed, then removed 3-7 seconds later, or do you want
(2) power applied after a delay of 3-7 seconds, and then come on and stay on?
Roff is offline
Old 8th November 2004, 02:12 AM   (permalink)
Any ideas??
Thanks!
Do you want
number (2)...
he wants to power his circuit after 7 or so seconds.
williB is offline
Old 8th November 2004, 02:20 AM   (permalink)
the 555 worked ... but it came on first then went off for x-seconds...then came on again.
I am sure that a simple couple of switches could solve the problem, switch # one to start timer , switch # 2 to connect the output to his circuit..
williB is offline
Old 8th November 2004, 02:51 AM   (permalink)
Yes Ron, as williB indicated I would like to have power after the delay and stay on.
Old 8th November 2004, 04:17 AM   (permalink)
Ok I have prepared a schematic based on Dingo's suggestions (I have adjusted the voltage for now, the final circuit will be 9v) The file is attached.
Thoughts??
Steve.
Ummm not quite.
See drawing below, quickly done in paint :roll:
When you press the button the relay will stay in, let go of the button the relay will still stay in until the cap discharges, that is your timer.
Flick the switch without pressing the button first and it is an instant boom fizzle ding of whatever you have connected to it.
The idea is, press the button and hold it in, flick the switch so it is closed (you are now armed), as soon as you let go of the button the countdown starts.
dingo is offline
Old 9th November 2004, 04:22 PM   (permalink)
Thanks Dingo. I have a question. If I hook up the following circuit 3v+ to 1100 uF capacitor to LED to ground, the led lights for about 3 seconds and then goes out once the cap is full. So using the same idea, if I go 3v+ to the cap, then to the relay, then to ground, the realy should open until the cap is full. Is that correct? So then using and SPDT relay once the cap is full and the relay switches, that will complete the secondary circuit which basically the cap supplying power to the LED (which in turn should light) is that correct?
Thanks again!
Steve.
Old 10th November 2004, 08:35 AM   (permalink)
Thanks again!
Steve.
Not sure what you are after here. Can you supply a circuit or discription of what you want to do?
Do you want the LED on while timing out?
dingo is offline
Old 10th November 2004, 04:10 PM   (permalink)
I think I may have confused things with my last post. I as only trying to acertain if a relay would behave in a similar fasion to an led once the cap had fully charged.
Here is what I am after (for information sake I should mention that the LED at this point only represents the device I am trying to control using this circuit so the voltage has been adjusted from 9v to 3v for simplicity).
I want to depress a button, 3-7 seconds later (the timing is not crucial at this point) I want the LED to light.
I'm not sure I understand why it is the schematic I posted won't work. Can you explain?
Thanks,
Steve.
Old 10th November 2004, 04:57 PM   (permalink)
Thanks,
Steve.
you have no power in the circuit with your LED...!!
williB is offline
Old 11th November 2004, 12:32 AM   (permalink)
The LED was never supposed to receive power from the battery directly.
I may have done the schematic incorrectly but the led was to be powered by the capacitor once it had stopped the power supply to the relay. Once the cap is full the relay would close again (theoreticaly) completing the LED circuit. I found that the capacitor once it is fully charged is able to light the LED (albeit on for a second but I think that is long enough for this application) I just haven't been able to find a suitable SPDT relay to run a test. The one I will ultimately need is 9v but none of the parts suppliers I have found have them in stock (even Radioshack). I have found several 12v SPDT relays, is it possible to increase the voltage before the relay from 9v to 12v??
:roll: This is getting complicated, I have to say thanks again for all of the help! You guys are great!
Steve.
Old 11th November 2004, 01:33 AM   (permalink)
i see what you are saying..
you were just using the LED to test the process..well you could still put a battery and a resistor and an led , on the right side of the circuit ,
for effect.. :lol:
a 12V relay would probably work , with 9 V..maybe.
williB is offline
Old 11th November 2004, 02:48 AM   (permalink)
I had no idea ops: perhaps I'll pick up a 12v relay and give it a shot!
Old 11th November 2004, 09:56 AM   (permalink)
A led will not behave the same as a relay. Look for a reed relay it uses less current so the cap can keep it in longer, you can also use more than one cap just keep adding them on. 5v relays might be the way to go.
Anything more complex and you would be better off with 555 circuit williB posted.
dingo is offline
