Old 29th October 2004, 11:19 PM   #1
Default on/off set/reset please help
there are two buttons On and Off. When the On button pressed a light turns on and stays on regardless of how many times the On button pressed. The light could be turned off only by pressing the Off button (providing that the Off does not turn back into ON)
I have a power supply 15 volts and I'm looking for a chip (CMOS) that I could buy fom Digi-Key
thankx
svtiss is offline
Old 29th October 2004, 11:45 PM   #2
This could be done very easily with a SCR. Press button to fire the SCR, it will now stay on as long as sufficient DC is flowing through it, then when you press the other button, it opens the circuit, the SCR turns off, and stays off.
All you would need is a normally open switch to turn the SCR on, a normally closed switch to turn it off, and 2 resistors to connect to the gate of the SCR to fire it from the first switch.
The SCR you get would depend on what the load is, and how much current it draws.
zevon8 is offline
Old 29th October 2004, 11:49 PM   #3
yeah 15 V is at the upper limit of CMOS...
williB is offline
Old 29th October 2004, 11:53 PM   #4
Try Mouser instead of Digi-Key, no minimum order. www.mouser.com
Russlk is offline
Old 29th October 2004, 11:58 PM   #5
thanks everybody for an answer, but I guess I did not explained myself well
by using a word "button" I wanted to show how I want the signal to work, I was not talking about actual buttons being there
I'm looking for a chip that would perform such a function
svtiss is offline
Old 30th October 2004, 02:54 AM   #6
Mouser does have minimum buys.. depends on what it is.. Digikey also lets you buy small quantities on most things.. they are similar in this regard. Wonder why you think mouser is better in this regard? In my experience, Ive run into the quantity problem more times with mouser than digikey.. but overall, I think they are similar.
Optikon is offline
Old 31st October 2004, 01:25 AM   #7
I checked some manuals and 15V is the upper limit on some , but not all CMOS chips , others are 18V .. so your 15V should work.But check the specs before ordering..S1 turns Led on S2 turns Led Off..R1's value depends on what you want to use as an indicator..R2 & R3 Should be 100K to 1Meg..
R4 = 100K ohms..
R5 & R6 =100K to 1 Meg
EDIT : Revised circuit..
on/off set/reset please help-on_off_circiut_192.jpg
williB is offline
Old 1st November 2004, 05:50 PM   #8
Thank you, that what I need , but what about D and CLK inputs, should I leave them how you showed, or put on high or low level .
thanks again .
svtiss is offline
Old 1st November 2004, 10:16 PM   #9
They can Float ..
williB is offline
Old 2nd November 2004, 06:12 AM   #10
CMOS ic inputs cannot be left floating, as will damage the IC. Also U have to tie all the other inputs, of the unused section to GND.
Gajanan Phadte
gmphadte is offline
Old 2nd November 2004, 06:17 AM   #11
i stand corrected.. ok then ground all unused inputs
please dont ground any unused outputs..
williB is offline
Old 2nd November 2004, 01:56 PM   #12
thanks for your help.
svtiss is offline
on or off, set or reset
