| | #1 (permalink) |
| Experienced Member | Does anyone know where to get one of those 9pin serial connectors(subd?) specifically for a breadboard, or a way to connect one to a breadboard. The ones i have are pcb mount but the pins dont conform to my breadboard so it doesnt fit, not to mention i had to tear of the solder lugs to even try and force it to fit. Can anyone help me out? |
| | #3 (permalink) | |
| Experienced Member Join Date: Aug 2004 Location: New Jersey
| | #4 (permalink) |
| Experienced Member Join Date: Jan 2004 Location: Kansas City, MO (United States)
| i'd get one of these types of connectors and solder wires into the cups to plug into your breadboard. http://www.jameco.com/webapp/wcs/sto...tegoryId=11479 they also have "PC Mount" connectors... but i have absolutely NO idea if those would work in a breadboard or not... i don't think the will since most appear to have the pins offset still. http://www.jameco.com/webapp/wcs/sto...tegoryId=11478 |
| | #5 (permalink) |
| Experienced Member Join Date: Oct 2003 Location: Maine, USA
| just snap off 9 pins from one of those 1-row breakaway pin headers, and solder wires to a d-sub connector. or if you want something a little more solid, do it on a perfboard or etch an adaptor board up if you want something more polished looking and permanent. |
| | #7 (permalink) |
| Experienced Member | I already have the pc mount ones and like Plot said the pins are offset so it doesnt fit. Crust do you know where i can find one of those old cards? If i cant find one of them ill just solder some wires to the pins like everyone else suggests. Thanks for the help. |
| | #8 (permalink) | |
| | #9 (permalink) |
| Experienced Member | not necessairly perfect, they are the dual row headers, (0.1" spacing between all the pins, like a connector for a hard drive). so no matter how you connect it, you'll always have 2 pins connected to the same 5 pin row. (you need a 0.3" spacing between the rows to be able to connect it like an IC). I believe there was a topic a couple weeks ago talking about this problem. At least this is how the cables were on all the motherboards I salvaged. (and I've salvaged quite a few)
__________________ Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. |
| | #10 (permalink) |
| Experienced Member Join Date: Sep 2003
| [quote="jrz126"]not necessairly perfect, they are the dual row headers, (0.1" spacing between all the pins, like a connector for a hard drive). so no matter how you connect it, you'll always have 2 pins connected to the same 5 pin row. (you need a 0.3" spacing between the rows to be able to connect it like an IC). [quote] True, i gathered people realized that you need to stick something between the connector and the breadboard since they are both female. I usually use a 5 pin header, since projects rarely use more than TX,RX,GND and all of them are on one of the rows. |
