Old 27th October 2004, 10:35 PM   (permalink)
Default what do these part look like?
wanna make a lie detector, what is a
5K Pot
0-1 mA Analog Meter
what do these parts look like?
thanks max
Maxer is offline
Old 27th October 2004, 10:51 PM   (permalink)
would this be a good or correct 5k pot for the lie detector test? i am about to purchase a few
thanks
Max
Maxer is offline
Old 27th October 2004, 10:54 PM   (permalink)
Pot is short for potentiometer which is a variable resistor. The 5K is the maximum resistance. Pots have 3 legs and will have a knob or screw that lets you change the resistance.
An analog meter could be a couple things but most likely its an electromechanical indicator - a needle with an electromagnet that moves the needle based on voltage
You might want to start with something a little easier than a lie detector. Try building a couple op-amp amplifier circuits first - these will be easier to test and less frustrating.
bmcculla is offline
Old 27th October 2004, 11:03 PM   (permalink)
thank you for explaining
where can i find these op-amp amplifier circuits? what is the primary purpose for these?
thanks
max
Maxer is offline
Old 27th October 2004, 11:10 PM   (permalink)
If you do a google search for op-amp circuits you should get tons of hits.
Opamps are an easy component to use to amplify signals. There are tons of ways to use opamps: filters, voltage to current converters, Waveform generation, etc.
You should try a simple inverting amplifier and non-inverting amplifier to start.
bmcculla is offline
Old 28th October 2004, 05:08 AM   (permalink)
Hopefully the author builds only pretested designs to get his feet wet.
Haphazard work is a surefire way to frustration!
Optikon is offline
