| | #31 | ||
i had a fan for the heater core go on me once ..heated the brushes up so much that it melted the PLASTIC that held them in place.. this was caused by the bearing which was putting a drag on the motor .. | |||
| | #32 | |
Either it is being overstressed by the environment (i.e. operating out of specs) this could be nasty voltages, insufficient airflow etc etc.. Or, there was something wrong with it to begin with as you mentioned. ISO9001 seems fairly confident that it is not overstressed by the environment so a manufacturing defect of sorts is not out of the question yet.. at least until more data is discovered. ISO, slow blow types are what you want (for inrush current reasons) but the rated carry capacity, you want to have not much above what the fan actually needs. Also, if it can carry full rated current for many hours, thats more than enough! If the fan is trying to remain running for hours then something else is wrong because its not doing a good job cooling. | ||
| | #33 | ||
maybe hook the base of the fet to two or three pins of the PIC with a resistor on each pin, output 111 to get full speed, 100 to get slowed down mode. | |||
| | #34 |
I might as well throw in my 2 cents worth, #1 check that the fan is blowing toward the engine when energized , #2 check that the fan does not come on until the engine has heated a little above normal, not as soon as the engine is turned on. # If the two above are correct check that the fan turns off when normal operating temp is reached. I suspect that one or more of the above conditions are not being met. Dave | |
| | #35 | |||
| | #36 |
oh hell. I still have not found out what is wrong with the fans, but I did speak to another tech who said "yea, thats kind of a bullsh¡t answer" so I'm trying a newer slightly larger fan. Same diameter and everything just a larger motor... After speaking with a lot of different people I'm starting to think that maybe I just got 2 bad fans. They DID come out of the same batch I believe I'm starting to think that nothing I have is screwed up. YES for the last time the fan spins the right way. YES my pic turns it on and off at the right temps w/ a 10degree dead band. Seriously, using a mosfet AND a D/A? This is a 15-20amp fan. You do NOT want to try and use resistors, they'll be huge and hot. If I wanted to slow it down a little, PWM is the way to go. I recently found out thats how the OEM does it. Mosfets may be better then my NPN (which I'm pretty sure will last forever). But they are too damn sensitive for my liking. No one at this company ever heard of two bad fans, hell most people never ever ever heard of one. But since I cant figure out whats wrong with it, I'll just toss a new (free) fan in and watch. | |
| | #37 | |
BTW is there any way to test the fan before installation..?? | ||
| | #38 |
A friend of mine had a similar problem with his “toy” Camaro many years ago. The fuse blew but only when he was driving fast, never when he was waiting for the red lights and the fan was starting and stopping all the time. He asked me if I could check his alternator and I did, nothing wrong here. I checked the rotation and the wiring and relay, all in good condition. Then I put in an A-meter so that we could measure the current while he was driving. When driving slowly down the street and the fan kicked in the meter showed 25A very shortly and then stabilised at about 10A until it stopped. But on the country road doing 100 the meter went out of scale (50A) and the fuse blew. After some tests we pulled of the hood with the scoop (fibreglass) and tried again …no problem. The scoop was the culprit catching lots of air at high speed making the fan go backwards. I don’t know if you have any scoop on your hood but if you do check if the fan is going the right way when driving. If the fan has a PM motor it’s easy just connect a voltmeter and you can se the polarity of the generated voltage and you know which way it turns. Ante :roll: | |
| | #39 |
Resolution ! I got my new fans in today and so far so good. No problems, tried to abuse it all day and its working fine. Looks like maybe I just got a bum fans from a company that tells me they have never before seen a bad fan at all. Go figure I get the only two ever made wrong. :? Thanks for your help everyone, | |
| | #40 | |
| | #41 |
You could posibly put a large capacitor paralel to the fan to filter the spikes I guess. Would this help guys?
| | #42 |
Have you tried connecting the fans positive straight to the battery with an inline fuse, and the negatve to a switched relay. I have connected mine this way with no problems.
| | #43 | |
__________________ Dean Huster, Electronics Curmudgeon Contributing Editor emeritus, "Q & A", of the former "Poptronics" magazine (formerly "Popular Electronics" and "Electronics Now" magazines). R.I.P. | ||
| | #44 | |
Not so much with (ordinary) *electronic* circuits because they rarely draw more than an amp or two anyway. As far as the fan motor is concerned, is this occuring in the wintertime or a cold environment? The time frame wasn't specified. I have a general motors vehicle that has a "secondary intake" fan associated with the manifold. I get a check engine every few months because I have a bad checkvalve that allows condensation to backflow and either rust the bearings or freeze and sieze the motor in cooler months. Instead of replacing it for the third time I have decided it is an unnecessary nuisance warning with minimal effect on my fuel efficiency and emissions. I'm a year away from replacing the vehicle anyway. At any rate, just a thought if Ice may be your culprit, or at least might have been for one of them. | ||
| | #45 |
Also remember, my question may be dumb for those of us in the Northern hemi who are just coming into the winter months, but I know Southern hemi posters abound here as well.
| amperage, broke, excessive, fan |
