| Hi, i am constructing a mini car using dc motors. I plan to 2 motors. The rear motor will control the 2 wheels at the back of the car to move forward or backward. The front motor will control the left and right turn of the car. How do i make the motor control the movement of the wheels (eg: if motor spins forward, the front wheels will turn right) ? | |
| for a steering setup like your taking about, youll want a servo motor. I think they work by sending a pulse width modulated signal to the servo, and depending on this signal the motor will rotate to a certain position. google for them, there should be a bunch of info out there.
__________________ Jeff Zimmerman To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| i dont know if you're already too far into construction to think about this. It would be kind of cool to make it steer like a tank does. If the left wheels go forward, and the right reverse, the car will turn to the right, adn vica versa. I think bobcat tractors work like that too.
| i dont know if you're already too far into construction to think about this. It would be kind of cool to make it steer like a tank does. If the left wheels go forward, and the right reverse, the car will turn to the right, adn vica versa. I think tractors work like that too.
| yep tank stering is much easyer to do and it makes it more manuverable (it can turn on an single spot).this works wery good whith 2 wels I made an simple lego car to try it out (2 strong motors made it wery fast).but i didnt make it radio controled(it was on an 10m wire). PS: I think trators sitil use tradiconal front weel angle stering
| i can understand how this works wen the car is not moving, but how does it work when teh car is moving? One wheel just slows down? i knew that it works, but not sure how.
i hope that helps | ||
| cool :lol: thx
