Help needed with High Power LED driver for Car
12 Last »
  1. #1
    stl_jones@yahoo.com stl_jones@yahoo.com is offline
    I have no idea on how to design a LED driver, so I decided to look for one online and found this.
    I will be using another circuit to switch the LED's on and off with the music.
    So will this circuit be able to switch on and off extremely fast? And will it be able to handle the voltage spikes in the car?
    Also, In my filter/amp circuit, on the output FET, I have LED anode's connected to V+ and am switching the cathode on the drain.
    How should I use the filter/amp circuit to switch the high-powered LED's in this circuit?
    crutschow crutschow is offline
    If you add another transistor like Q1 connected from Q2's gate to ground you can use it to turn Q2 on and off. Put a resistor in series with the base of the added resistor (no greater than 10 times the value of R1). Connect this resistor to the filter/amp circuit. A high voltage at this resistor will turn off the LEDs. Less than 0.7V will turn the LEDs on.
    The spikes it can tolerate are determined by the voltage ratings of Q1 and Q2. To be on the safe side add a small resistor in series with the + power and add a large capacitor (100µF or larger) from the circuit side of the resistor to ground. Select the resistor size to generate a 1-2V drop at the LED current level (R = V/I).
    0
    Zapper
    Curmudgeon Elektroniker
    --Inside every little problem is a big problem trying to get out.--
  3. Thread Starter #3
    Thanks for the reply.
    I have little idea what is going on in this circuit, so if anyone could give me a little walkthrough I would appreciate it.
    As to the voltage spikes, I'm not worried about the transistor blowing up, but the $40 LED's.
    I need to ensure that the LED's can only drop 4.3V at 1000mA
    0
  4. #4
    You don't concern yourself with the voltage drop across the LEDs. They will drop whatever they need. You are concerned about the current and that is what this circuit regulates.
    The two transistors are configured as a constant-current source (current independent of voltage). Initially Q2 turns on due to the positive bias voltage from R1. When the voltage across R3 due to the current through the transistor and R3 reaches about 0.7V, Q2 turns on and reduces the voltage at the gate of Q1 to maintain 0.7V across R3. Thus the current through the LEDs stays a value of about 0.7V/R3.
    You select R3 to give the desired current. In this case you want 0.7V/1A = 0.7 ohms. If you can't find that value you can parallel two or more resistors to get the desired value.
    Be aware that Q2 will be dissipating over 8W when operating and will need to be on a heat sink.
    You need to be concerned about the transistors blowing because if they blow, that can cause the LED current to increase and blow them also.
    But as an alternative circuit I recommend using an LM317 regulator in a current limit configuration (see this). It requires only one resistor and the regulator automatically protects itself against over-current and over-temperature. It also will require a heat sink. A resistor capacitor filter at the power input as I previously described is also recommended.
    0
    Zapper
  5. Thread Starter #5
    Ok thanks for helping me with all my newb questions.
    How can I test this circuit before using the expensive LED's on it? Thanks
    0
  6. #6
    colin55 colin55 is offline
    Explain exactly what you have that creates 4.3v LEDs at 1,000mA
    0
  7. #7
    Diver300 Diver300 is offline
    Quote Originally Posted by stl_jones@yahoo.com View Post
    Disconnect the LEDs, and put an ammeter in their place. It should show around 1 amp. Q1 will produce more heat during that test than in normal running so you should keep the test time short.
  8. Thread Starter #8
    Ahh, good idea. Didn't realize I could just short the drain to V+. Thanks!
    0
  9. Thread Starter #9
    Quote Originally Posted by colin55 View Post
    Some 5W High Powered LED's
    0
  10. #10
    How many?
    This exercise is like pulling teeth.
    0
12 Last »
High Power LED Driver Circuit Help.. cobra1 Electronic Projects Design/Ideas/Reviews 24 17th May 2010, 10:10 PM
Help needed with MAX7219/7221 LED driver IC HexTheKiwi Electronic Projects Design/Ideas/Reviews 4 4th January 2010, 01:17 PM
Help needed with power supply for circuit Brass General Electronics Chat 1 5th October 2009, 02:12 PM
Help needed with power supply RC filter repair jfs Electronic Projects Design/Ideas/Reviews 16 21st November 2007, 12:13 AM
Help needed with LED Bar Current Meter! blue7hand Electronic Projects Design/Ideas/Reviews 6 28th February 2005, 11:40 AM
Page Time: 0.12875 seconds      Memory: 7,656 KB      Queries: 16      Templates: 0
