Needs advice / suggestions / opinions badly... :cry: :cry: :cry: Btw, issit advisable or practical to implement a PIC microcontroller for the battery monitoring portion? Or should I just implement a DOT matrix driver and develop a circuit to monitor the condition of the battery? But if i were to implement a PIC microcontroller, what are the features can I include in it? Any suggestions? Please?
Lord Robert Stephenson Smith Baden Powell\'s last message : -BE PREPARED- |
Using a PIC for this gives many advantages, for example a non-linear scale (if required), and a scale that doesn't start at zero - with a 12V battery you only need something like 10V to 15V range - you can easily adjust the PIC software for whatever range you want. If you plot the discharge curves for the battery you can decide at what exact points you want the different LED's to light - and this isn't likely to be on a linear scale!. Funnily enough I was playing with PIC LED meter's a while back, I programmed one to replace the usual LM3914/5 designs - using a 16F876 it provided two 16 LED columns, switchable via a single pin to either a log or linear scale, another pin selected either dot or column mode. |
Thanks for that idea! Hope you dont mind giving me ur opinion about the following:
I was thinking to increase a lil of my budget and get a backlight LCD for the monitoring portion. Will this be very troublesome? Frankly, I've not touch PIC microcontroller before. I'm now in ur tutorial page..thanks
Real sorry for asking the following:
Can I perform some calculations and have the PIC microcontroller to display the following details through the LCD? a.) Percentage or level of battery at the moment. b.) Approximate life-span of the battery under the current specific load.
Thanks...
Nigel? I think I'm not suppose to ask this but do you mind letting me know the exact PIC that I should use if the functions that I intend to have in the LCD (16x2) are: a.) Load current b.) Approximate battery life c.) Battery level Real sorry if Im not suppose to ask such direct question.
Hi there, I get what you mean regarding how difficult as well as dangerous it is to build switch mode power supply.
But, if I still intend to build one, a 240V AC to a 12V DC switching regulator (to an appropriate level for charging), do you mind guiding me? It's okay if you're busy
Approximately 2 months time, it dues on end of January. Do you think that a blur-newbie like me can make it?
I've not started much, the previous circuitry that I came out with are all linear regulators and I'm now suppose to implement switching regulators. In other words, the previous prepared circuits cannot be used. I need to try my best and learn up to improve the efficiency. :cry: Really hope you dont mind guiding me all the way...Help needed.....Please?
do yourself a favor and order your Pics TODAY .
order 2 16F648A has on board A/D converter and 2 16F84A Just to get you going and is less confusing.. and another F648 if you like.. |
Nway, I will take ur advice but I think I will buy one of each, issit okay? Hope you don't mind, me, as a student, I don't have much to spend. So I will get one 16F648A and 16F84A? Thanks!
Alrite, correction, I will now order one 16F648A as well as one 16F628?
Thanks for the advice...
(permalink) | ||
