Lord Robert Stephenson Smith Baden Powell\'s last message : -BE PREPARED- |
If you're still talking about solar panels it's not needed at all, you don't have enough power to cause a problem. Try telling us EXACTLY what you are trying to do, with what voltages and currents, and why - it's been so long, and so many different threads, I'm losing count :lol: |
(Dotted lines indicate detachable while the box shows the Charging and Monitoring Unit) All this while, we have been talking about Battery Charging Circuit 1, which is the Boost DC/DC Converter. Was thinking to develop this circuit in such away where one can use different types of solar panels. Meaning, as long as the panels are needed to be boost to a certain level, it can be used. Thus, I was thinking to develop a circuit that takes into the consideration of preventing overcharging as well. I thought there are certain panels that are capable in doing overcharging this 12V 1.3AH battery? Thanks. And just to reconfirm about the circuit posted on page 7, entitled Boost Converter. Can I implement that, with the changes such as a MOSFET, a zener diode and the PWM from PIC?
(permalink) | ||
You could prevent over charging with the PIC as well, monitor the battery voltage and if it gets too high then reduce the charging rate via the PWM. |
(permalink) | ||||
The zener is not accurate enough to stop an overcharge. With a current of only mA, the voltage difference between charging and overcharging is small, less than the tolerance of the zener. Worry about overcharge if your current is going to be more than the 20-hr charge rate for weeks on end. Problem is, you're going to need a voltage divider (inaccurate and consumes current off the battery) and a more accurate voltage ref. Quote:
Also, a solar cell is going to drop down to a voltage which won't cause it to turn off but it won't run properly either. When the sun comes back and voltage is restored, it may not have a valid state and won't run. There are several mechanisms to enable that will compensate for this, look up "brown out detection". Did you ever decide what your panel voltage and current were going to be? I missed that. |
(permalink) | |||
Thanks for everything.
(permalink) | ||||||
(permalink) | ||
Say you want to use the average, optimum 40mA from the panel. If you have a 20mA peak-to-peak ripple due to a small inductance, the current will vary from 50 mA to 30mA. Look at the i/v curve for the cell. The voltage will drop to next to nothing if you try to draw 50mA, the power output is low. At 30mA you're not using the capacity of the cell. Now an input capacitor will help this to some degree, but it's not a magic bullet since the ripple voltage is much less than the current ripple due to the i/v curve of a solar cell. Caps are not as effective in this scenario.
By the way, don't use a normal silicon diode for the diode, that takes 0.7v. Use a Schottkey, it's around 0.3v forward drop. More efficient. |
(permalink) | ||
Solar power cars are NOT efficient in harnessing power. That is why I would use a 12D (jumbo size) battery with 14 inch modulators for that extra juice and power. Of course, you are going to have to find out a way to connect these large heavy duty batteries to the little solar car. Also, you should get 5 inch quadrum wheels to give it a lighter touch so that it can run more smoothly without friction. That should help your solar car run better. PLUS! GET LOTS OF LIGHT! :wink: You are going to need that.
__________________________________________________ ___________ THE WORLD ENDS AT EXACTLY 5:12:34 PM on December the 17th. We die a little more each day, but on December the 17th, we all die. |
Hi there,
After all the guidance and teachings from you guys...As attached is the present circuit which will be used for the Charging Circuit 1. In the meantime, I hope that this would be a great news as we are now given a better solar panel for this project. The solar panel will reach our hands by next week and I run a test on it to plot the IV Characteristic of it. However, according to the datasheet of the solar panel, its output voltage is 7.5V whereas the current at load is 150mA. (The one earlier was: output voltage = 7.5V, current at load = 40mA) :arrow: With reference to the attached circuit, the value of the inductor and capacitor is still under consideration. Is it true that proper selection of the inductance and capacitance value can only be done through testing to see the ripple? Or calculations can be done? :arrow: I'm still searching for the appropriate NMOS transistor for the MOSFET.
Gather 'round and listen to the tale of the End of the World. It all began at the Pumonkey Convention of 1854. A well known scientist and astrologist, Herbert Fabio van Stooben, had made a world braking discovery. This amazing discovery was the date of the End of the World. And this is how he found it:
By measuring the circumference of the moon each night, he found that it was approximately shrinking by .0000000000001 mm each night. 'Twas the beginning of a new era, the Era of Beginning. This was the start of the quest for knowledge and discovery...the discovery of the End of the World. As van Stooben continued to study he also found that the world was heating up by .00000001 degree Celcius each day. After making calculations, he found that at December 17th, it would all be too much. The moon too far would fling the Earth out of place and the heat would burn us all. We will fling to the Sun, and without an ozone layer, we will burn. Thus, ends my tale of Herbert Fabio van Stooben. And it is independently. Each time zone that hits the time will die. :twisted: |
