+ Reply to Thread
Results 1 to 10 of 10
Thread: Help to identify a semiconductor
  1. #1
    vlad Newbie
    Join Date
    Oct 2004
    Posts
    1
    Default Help to identify a semiconductor
    I have a Brother HL-1030 printer.
    The cartridge part # is TN6300, which is composed of toner unit and drum unit TN6000.
    Last week the printer started to leave unused toner on the paper, so all surface of the paper is grey.
    The photo drum is cleared from unused toner by a brush which is electrified in order to demagnetize it, so the drum stays always clean.
    The current passes through a semiconductor! When I checked it with tester - no signs of life.
    So I think, that it's because of this semiconductor.
    So please, help me to identify the component and where can I buy it or maybe it's analogue.
    Photos of this element are attached or you can find them here:
    http://www.angelfire.com/un/vlad/
    Thanx a lot
  2. #2
    Styx Good Styx Good
    Join Date
    Dec 2003
    Location
    UK
    Posts
    1,724
    that is a resistor
  3. #3
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Yes, and probably too high a value for it to be tested with a meter!, I can't make any sense of the writing on it - but it could easily be in the 100's of megaohms?.
    I would suggest he measures the input voltage to it, which is likely to be kilovolts - I would have thought it's more likely that the EHT circuit has died than the resistor failing!.
  4. #4
    pike Newbie
    Join Date
    Oct 2003
    Location
    Sydney, Australia
    Posts
    589
    LOL
    That certainly looks like a resistor to me :lol: :lol:
    www.winpicprog.co.uk - Great PIC language tutorials.
  5. #5
    Sebi Newbie
    Join Date
    Jan 2003
    Location
    Hungary
    Posts
    1,717
    I mean, the background on paper not a high voltage supply problem. Maybe the drum discharger lamp not work properly, and remain some charge on the drum...
  6. #6
    Styx Good Styx Good
    Join Date
    Dec 2003
    Location
    UK
    Posts
    1,724
    Quote Originally Posted by Sebi
    Err??? how can you say "I mean" when you havn't posted? and also correct yourself when talking abt high voltage when you havn't posted?
    Unless you and Nigel are one and the same person???
    interesting... :shock:
  7. #7
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Quote Originally Posted by Styx
    Bear in mind his location (which, happily, is filled in!), it's HIGHLY unlikely that English is his first language, and may not even be his second language?.
    So it's reasonable to give him a little slack, I presume he means that the high voltage being missing wouldn't cause this fault?. I've no idea?, I've never had anything to do with photocopiers or laser printers.
  8. #8
    Styx Good Styx Good
    Join Date
    Dec 2003
    Location
    UK
    Posts
    1,724
    I take it its that time of the day when Irony doesnt seen that ironic...
  9. #9
    zachtheterrible Newbie
    Join Date
    May 2004
    Location
    California, USA
    Posts
    2,160
    thats 1 high resistance!!
    Maybe the 9x means 90M ohms??
  10. #10
    Styx Good Styx Good
    Join Date
    Dec 2003
    Location
    UK
    Posts
    1,724
    --EDIT--
+ Reply to Thread
Tags for this Thread
