| I have a 400 watt inverter: I want to run my laptop and Canon inkjet printer in the field. Inverter will run the laptop but not the printer. Printer uses 24 watts laptop 120 watts . red light blinks when I have printer pluged in with or with out the laptop. I have a 90 watt inverter using it from the same cigarette 8) plug, the printer works fine. Not enough power for both.. Any help would be welcome. bob | |
| I think it has something to do with the “quality” of the AC produced. The power supply for the printer can be more “picky” than the supply for the laptop in a way that makes it draw much more current than it normally would. But this is just my theory. Ante :roll: | |
| I agree with ante..Some inverters put out a square wave and others a modified sine wave. Some electronics don't like the square wave at all. Do you have the specs on both inverters? Compare the waveform outputs and that may be your asnwer...
__________________ gerty | |
| I have a 400W inverter made by Coleman, I had a similar problem with mine, only it wouldnt work at all (I think, I cant remember if I only tried using my playstation 2 on it or not). Anyways, I called the tech support number and they had me do a couple of tests on it, and they said to send it in and they would send me a new one. (They also wanted a copy of the reciept, but I bought it off ebay so I didnt have one, and they still gave me a new one. :wink: ) Hope this helps
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |
| | (permalink) | ||
__________________ Jeff To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be. | |||
| Try what tech support said, connecting to battery.. If that doesn't work I'd say they're not compatible, or?? Have you tried any other loads on the 400 yet, something of equal or higher current draw than the printer, and are you sure the printer only draws 24w?
