Old 7th October 2004, 02:25 AM   (permalink)
Default Low offset, low noise op amp recommendation
I have a couple of silicon strain gauge pressure sensors which are inherently quite noisy (500Hz - MHz range), but I must have a high accuracy reading out of a 16 bit op amp. Oversampling was not helpful enough, so I need to construct a lowpass filter, but the ADC will have an unacceptable loss of accuracy with the high source impedance.
So, I need to add a 1:1 buffer after the filter. It needs to be as low offset as possible, as well as low noise since the whole point is to lower the noise.
It's powered by a single 5v supply and the signal on one sensor swings to 4.1, but the other can swing to 4.95v, which may mean I need to select another sensor since fewer buffers can go rail-to-rail in 5v (voltage dividers are bad for accuracy so I will be staying away). Power output and supply current are not an issue.
Any recommendations? There's just a crapload of op amps out there and I'm going to looking through specs for awhile.
Oznog is offline
Old 7th October 2004, 10:08 AM   (permalink)
Not sure what you meant by 16 bit opamp exactly...
but i use this one often, has low offset, maybe it'll send you in the right direction:
http://focus.ti.com/docs/prod/folder...t/opa2132.html
plot is offline
Old 7th October 2004, 02:30 PM   (permalink)
Default Re: Low offset, low noise op amp recommendation
A couple low noise choices to consider.
LT1028 / LT1037 from linear.com
OP184 from analog.com
OPA228 from ti.com
LM833 from national.com (very nice cost)
MAX4475 from maxim-ic.com
Happy hunting!
Optikon is offline
Old 7th October 2004, 09:25 PM   (permalink)
When you say oversampling, does that mean you already tried software-based filtering?
Roff is offline
