Old 21st September 2004, 06:02 PM   (permalink)
Default Quick Question about protection diodes
I ran out of signal diodes so I used an LED instead of a protection diode.
The diode protects a transistor from its inductive load (coil of a relay).
The problem is the transistor only works intermittently.
Could this be caused by using an LED instead of a normal diode?
Cheers
The first rule of mstechca club is do not talk about mstechca club.
http://www.electro-tech-online.com/s...induser&u=1245
2camjohn is offline
Old 21st September 2004, 07:16 PM   (permalink)
YES!!!!!!
LED are special case diodes, their reverse blocking is only in the order of 5V, anything more and they avalanch
Styx is offline
Old 22nd September 2004, 01:14 PM   (permalink)
Default Re: Quick Question about protection diodes
Cheers
Get rid of the LED.. if you absolutely cannot find a diode (not even in the scrap pile?) at least use a transistor connected as a diode! You can do this with bipolars or Fet types... if you use a bipolar, don't use the base emitter junction though because it will breakdown at around 7V more like a zener diode than a normal one.
Also keep in mind, diodes made like this are not fast, they have recovery times on the order of hundreds of nanoseconds..so it might STILL not be good enough for you, but you can try it!
Optikon is offline
