Power supply design for beginners
« First 123456 ... Last »
  1. #11
    Mosaic Mosaic is offline
    I could use some advice concerning microwave oven transformers.
    I know these MOTS tend to saturate under low load and this causes energy wasted as heat in the primary.
    I want to remove the step up secondary and replace it with a 12 AWG step down to about 28VAC. That may require around 28 to 35 turns of wire from general MOT winding data.
    My issue is this. I want to reduce the losses due to MOT saturation. I can separate the E and I sections of the core. Would it be acceptable to add a small air gap between the E&I sections of the core to limit the saturation of the core? How would this affect my output....would I need more wire turns etc? I'd like to see perhaps 15 to 20Amps full load output,5 V drop. The MOT is from a 1.2KW microwave. I understand adding more soft iron to the core can also offset saturation. If I build layers of 2 mm thick headless nails (individually dip varnished) stacked to extend the E core, how shall I calc the mass of iron nails I need?
    Adding more windings to the Primary may be possible, but it looks kinda tight.
    Thanks for any advice.
    0
  2. #12
    audioguru audioguru is offline
    I think that a microwave oven transformer is made as cheap as possible so it is not efficient. The microwave oven is used only for a few minutes at a time and it has a fan so its transformer does not heat much. The core is too small and its primary winding has not enough turns for continuous efficient use.
    0
  3. #13
    These are informative links
    http://www.allaboutcircuits.com/vol_2/chpt_9/8.html
    http://www.butlerwinding.com/store.asp?pid=28355
    http://www.electro-tech-online.com/c.../Ch12slide.pdf
    Perhaps a current limiting circuit on the primary may be the solution.
    Here's a useful tip:MOT windings =>> 2500 turns on sec and 110 on prim and 4 on the third coil, on a standard US microwave.
    0
  4. #14
    Shyamal Shyamal is offline
    Yes really helpful video that is simple for new maker.
    -1
  5. #15
    sz-aiden sz-aiden is offline
    Appears to be a good idea
    0
  6. #16
    Electronical Electronical is offline
    Yes, very nice an simple!
    0
  7. #17
    very nice video. any one can do it
    0
  8. #18
    pushpa pushpa is offline
    Helpful videos ,Really very good
    regard's
    Pushpa
    0
  9. #19
    KeepItSimpleStupid KeepItSimpleStupid is online now
    afroman:
    You do a nice job. Both a simple explanation and the hint that it's different as you learn more.
    0
  10. #20
    jadot29 jadot29 is offline
    That was a very helpful video. Where would you suggest someone just getting into electronics start ?
    0
Beginners circuit design program for free? Tipsy General Electronics Chat 13 3rd February 2010, 11:03 PM
power supply design yohanevindra Electronic Projects Design/Ideas/Reviews 13 14th October 2009, 04:28 AM
power supply design bejoy_ak General Electronics Chat 3 21st May 2009, 09:45 PM
Nice regulated power supply for beginners, only $19.95 TheOne General Electronics Chat 0 28th January 2005, 10:08 PM
Power supply/ current supply design inkedallusion Electronic Projects Design/Ideas/Reviews 1 17th December 2002, 01:10 AM
Page Time: 0.06968 seconds      Memory: 7,658 KB      Queries: 16      Templates: 0
