| Hi, I'm using a pic to read in a square wave at 8V... To do this I'm running though a resistor and then spliting to my pic and a zener diode connected to ground. End result is that my pic can see 0V and 4.5V for the high of the wave. Now I've decieded I want to also transimit on the wire the wave is coming in on. I plan to wait for a long silence and then begin transmitting via turning the pin high and low, creating my own wave on the wire I already have coming in. My problem is I have no idea how to send 5V out of the pic and have it go into a transistor of some sorts, and then have an 8V signal get into the square wave wire. A problem I see is that I believe I will be cutting my own signal down with my resistor/zener setup that I need to read the signal in. Ideas ? | |
Transmitting on the same wire depends on how it's connected elsewhere, as long as it's connected via open-collector drivers with a pull-up resistor you could easily do it with a single NPN transistor and one resistor. If it's not done in that way it might not be possible, you really need to post the circuit diagram for the other end. You also, obviously, need to implement a suitable protocol for the communication - at both ends. Also, 8V is a strange level, how come?. This is what worries me about making the link two way!, I suspect the other end isn't built by you, and you don't have design access to it?. | ||
If it really supports 2way communication over 1 wire then it's very likely to be a open-collector bus (the wire beeing pulled to 8V inside the device witha pullup resistor). If you were to force 8V into it you might damage it. | ||
| The a good assumtion that I do not have access to the other end Its an automotive iso9141 bus (very similar to J1850 except for the data layer) I believe that it is weakly pulled to ground. Any node speaking on it outputs 6-8 and then can simply 'let' the bus return to ground or force it to ground by sinking an ouput. What I am doing is basicly adding my own node. Are you sure about the not needing a diode? I can see that the voltage is 4.5-5 at the pin, I'de be a little worried just letting 8V into it and assuming that its just going to be ok. The spec calls for 6-8V ouputs... I've read that it may possibly accept 4.5-20V for inputs... My guess is that it would accept 5V just fine and that the 6-8V is required for noise or somthing like that. Its likely I could just hook it up to an output and VROOM away I go. The bus being pulled up would also be my first guess, however the sheet says "weakly pulled to ground". The only papers I can find for it are titled "Implementing J1850 Bus" by intel. The link is the first hit of google i think, I cant get onto google now or I'de post it. | |
| iso9141 is an open collector bus, like i said... You only need to be able to read it and pull it low. You should never directly put a voltage on it, this may damage the device. The wire should be pulled high with a resistor, eighter in the device, or by you if it isn't already pulled high... You can use a single pin on your pic to read/write this bus, by tri-stating it. iso9141 is sort of a cross between I²C and RS232. The setup of the dataline is similar to I²C, but there is no clock line, it uses start and stop bits similar to RS232. | |
| The bus is definetely zero volts at idle. I think its almost a sort of bastardized hybrid... Its almost exactly J1850 except that it has some difference in the data layer (like how long 0s and 1s are, plus there is no CRC) I'm sure that while the bus is idle it is 0v, | |
| It could just be that the device expects the pull-up to be external, so you should incorporate it into your design. You really should exactly know what you're dealing with. | |
As for adding your own node, you need to know exactly what is going on, both in hardware and software - from your posts so far, it looks like you know neither?. | ||
| how can i descramble a cable box | |
| WOW. Thanks.... Instead of helping me figure out the cleanest way to do this, I get "Um... You don't know enough about the system"... Well no sh¡t I don't know. Thats why I'm asking. The bus is normally Zero Volts. Elm has a digram for thier J1850 chip that has a cluster of things going on to deliver 8V into the line. I put thier diagram into a simulator and I cant get it work, I have no idea what they're doing so I don't want to incorperate it. (Not much sense just copying if I don't know whats going on...) This bus is not rocket sciene. It is normally low and fed 8V to make the wave. I KNOW of at least one diagram to do this but I dont understand what they are doing (2 transistors, 2 resistors and a diode JUST on the output line? Thats seems a little much. Also, if what Nigel says is right, then why does Elm put 3 resistors and 2 transistors JUST on the input line... Don't they know all they need is a limmiting resistor ? Here is the link to Elm's datasheet, It has 2 diagram at the bottom, one for ouputing 5V and one for outputing 8V.... I think they are overcomplex. http://www.elmelectronics.com/DSheets/ELM322DS.pdf | |
| i found another circuit which is titled iso9141-2 to RS232 interface.. hope that helps. http://www.planetfall.com/~jeff/obdii/schematic_b1.pdf | |
| I was building that interface and it didn't work for me (it might work elsewhere but sure didn't like to talk to ECUs we had to work with). We had the same problem with all commercial products we could find (NetWay, B&B electronics and Scantool - which actually uses ELM chip which is really PIC). we started this ca two years ago. I am sure all these guys have worked out solutions by now but at that time we ware quite desperate to get working interface so simple schematics like in previous post seamed attractive enough to try them out. Unfortunatelly first two didn't work for us and we all had sinking feeling and then I came accross circuit that was using MAX232 and 7407. Quick comparison with the block diagram of the ISO9141-2 chip confirmed same inner working. I've built the first unit and after it worked, I asked our technician to make more. (so far we did ca 30 of them). For your circuit (it uses PIC) I would recommend simple interface like in the K-Line of following drawing. I'm no expert in Russian language but you should be able to copy two transistor circuit up to schmidt trigger inverters and substitute those components with parts you keep in your drawer. http://www.radioland.net.ua/images/Avto/auto_comp1.gif | |
| Btw. the K-line is normally high (+8 to 12V). It is pulled low by transmitting node. L-line is only used for initialization and most systems don't use it (I've not seen one yet to be honest). The inverters KR1533TL2 are same as 74ALS14 according to chipdir. Zener diode KS133 is supposedly 3.3V. Transistors KT3102V are equivalent of BC546B,C; BC547B,C and also replace the KD522 diodes with 1N4148 for example. Hope this helps. | |
| I'll look over those diagrams in a bit. Did you say one uses a MAX232? I'm VERY VERY certain that the line is not high and is pulled low. It is identical to the J1850 bus except the data layer (it has some odd symbols and timings... The data layer is close to iso9141 / No CRC) This paper here tells what I'm dealing with (sorta): http://www.intel.com/design/intarch/papers/j1850_wp.pdf I just want to send 5V out to somthing and have it allow 8V to get onto the bus line. I cant any (understandable) transistor configurations to work | |
