| hi is double inverting using 741 is possible :shock:
__________________ plz help friend,s | |
| By double inverting do you mean double invert the polarity? If you double invert any signal you will get back what you started with. e.g invert +5V to get -5V invert -5V to get +5V sorry if i have missunderstood your question but it seemed a strange one to ask thats all andy | |
| or is it like to produce a delay line or make a buffer type of thing. like in digital electronics u can put two logic inverters to produce a delay? | |
| The LM741 is a single OP Amp, so I don't know what he's getting at? With a single inverter you can only invert once. If you wanted to, you could configure it as a buffer and then say the signal is inverted 2*n times. j. | |
| friends i want to feed 10voltage and want to get 20voltage ..... :!:
| what does that suppose to mean?? are u asking for a 10V to 20V DC-DC step-up converter?? try to explain things a little bit :!: | |
| yes u r right i need to convert 10voltage into 20voltage ....... :roll: is this -Non-inverting Operational Amplifiers worki for me and who circuit will help i guess
| are you after 10V POWER to 20V POWER?? If that is the case you need a DC If you are after 10V SIGNAL to 20V SIGNAL use an OPAMP but arrange it as a non-inverting amplifier instead of an inverting amplifier The gain of an inverting amp is -Rf/Ri The gain for a non-inverting is 1+ Rf/Ri So by using the feedback and input res as both 10k you will get a gain of two. Search google for "non-inverting amplifier circuits" | |
| I highly doubt the humble 741 can achieve the output voltage swings you require, not to mention that you would need a reasonably high voltage dual supply. If you have a lower power supply, use a DC-DC convertor. Else use a voltage regulator, or a series of zeners for low-current applications. | |
