| I have a 128 MD SDRAM module (PC133) One of the edge contacts on the module has a bad corrosion on it. Its turned green and rough. The module is still working. I dont want to toss it in the bin. At the same time I do not want to put it into my PC as the corrosion may spread to the memory contact in my PC. Question: How do I remove the corrosion ? are there any chemical that can be used ? Isopropyl does not work. I tried it. | |
| Clean it with an ink pen rubber......Old computor maintenance trick :lol: | |
| I already tried that. Does not work. The surface has turned green and is pitted. | |
| Try using a dab of paint remover or thinner. | |
| the green stuff it is probably copper oxide and it is not that easy to clean and it is toxic too. try, but i dont know if it will work, with cleanink powder and a towl moisted in water, but be careful not to get water all over it. i dont think that it will work but it is very possible. | |
| Ok I will try both approaches | |
| just be gentle! | |
| If that doesn't work try putting some drops of lemon juice mixed with slight detergent washing powder. Let the mixture be in solid form only. Now rub the powder on contacts. I am sure it will remove the green stuff. We use this method to clean copper utensils when they turn green. Make sure, lemon juice does not fall parts of PCB.
__________________ "There is no way to peace, peace is the way!" | |
