| well hello there... i know that my question will be somehow very stupid ... but sorry i m not that electornics expert... well when they say a 4 watt power amplifier ( by example ) what does it mean ??? that if the speakers are plugged into the amplifier and the amplifier is plugged to a voltafe source so the P= U x I would be 4 ?? i mean if i mesure the voltage and the intensity on the battery and the circuit .. the U would be 4 ???? sorry again for the question | |
The actual drawn from the supply will be more than the output power, as there are considerable losses in the amplifier - depending on it's design. However, these figures will depend entirely on the type of signal through the amplifier, and how loud it's turned up. | ||
| ok 10x for replying .... i ll try to explain the problem i m having i m trying to build a similar amplifier to a one i have here .... well when i turn on the amp and i mesure the intensity on the input it s 0.15 A the battery is 12 v .... the measurmentrs on the output can't be done i guess.... anyway ... if this is the case what do u think the internal amp is ??? i mean how many watts it is ?|??aproximately ... | |
| well 10x for ur informations again.... the speaker i have is a horn tweeter ... when i m putting it into the ohmmeter it s giving 2 ohms ( but with a bad ohmmeter.. when i rely his 2 borns with no resistor it give 1 ohm ... ) with another one more professional it s giving 1 .2 ohm ... so i guess it s a 1 ohm tweeter ... so it would be a 16 W RMS ??? what i mean is that the circiut i need should be a 16 W power amplifier to get the same sound power ?( theoricly and basicly ) ?? another question ... with this amplifier ... on the power input ... i should have the same internsity ??? 0.15 A ?? coz the intensity flow should be very low ... coz i need it to run on battery for a long time 10x again | |
As for power consumption, again it depends entirely on both output power and the actual waveform. | ||
| well i ve made some measurments on the output ... it s going between 0.3 V and 3 V so when dividing by 2.828 i would get betwenn 0.11 and 1.1 ... when squaring it would be 0.01 and 1.21 ... when dividing by 8( speaker impedance ) it would be 0.00125 and 0.126 W RMS ??? is that possible ??? so i dunno if i m making false mathematics here.. but all i want to know is that when i m using like u said a 8 Ohm speaker ... with a battery of 12 V and a sinusoidal sound on the output with high frequency ( about 3 to 10 Khz) i want that the intensity do not cross the 0.5 A on the power input ( the battery ) what is the maximum power of the amplifier that i can use ???? i mean which amplifier can i use for this maximum ?? | |
