Old 20th August 2004, 10:06 PM   (permalink)
Default Start with USB
Hello,
I' ve been doing some work on paralel port, but I wonder if it is time to start using USB. Any good place to start of?
What I really like doing is circuit controlling and data adquisition through USB.
anyway I read that USB speed is even lower than EPP's or ECP's paralel port... in this case, it is less interesting to learn how to use it, knowing how to use paralel port already... any advices?
thanks
patroclus is offline
Old 20th August 2004, 11:30 PM   (permalink)
It is MUCH! more complicated to use USB then using the parallel port. But if you realy want to get into it, there's an application note on microchips website for a USB pic programmer, wich exaplains usb.
you could also google for "usb specification".
In any case, you're going to need an advanced microcontroller to interface with it.
USB1.0 is slower then EPP and ECP, USB2.0 is way faster.
Exo is offline
Old 21st August 2004, 06:57 AM   (permalink)
I spent roughly 3 months, starting from reading of USB specs, coding the firmware of a usb device, to the development of a WDM USB driver. A fully customized USB pipe is no mean task indeed.
But of course, there are always short-cuts, like USB-to-Serial convertors, device class drivers etc.
checkmate is offline
Old 21st August 2004, 09:36 PM   (permalink)
USB 2.0 is the one running at 15 Mbps ??
In real world it never gets above 700 Kbytes / second. EPP/ECP is most of times equal or faster.
Old 21st August 2004, 10:04 PM   (permalink)
It can go as fast as 15Mb/sec, but the device on the other end has to support it.
Exo is offline
Old 9th November 2004, 01:13 AM   (permalink)
what would be the best/cheapest way to use usb for data acquision. I am looking to collect data (on/off) from a bunch of sensors, and process them with software. I have looked into the cypress usb chip (something one one of these http://www.cypress.com/products/data...D6D6&errataid=) but the programmer is about $100, a little over budget for my project.
zero_signal_69 is offline
Old 9th November 2004, 06:59 AM   (permalink)
There's a PIC available with in-built USB, the 16C745, but it's an OTP chip - however, a FLASH USB PIC is due out any time.
Failing that you can use an RS232/USB converter, and run your project as RS232 - this is a common way of doing it!.
Nigel Goodwin is online now
Old 9th November 2004, 08:52 AM   (permalink)
If you want to get into usb I suggest firstly looking at www.dontronics.com as Don has not only products like usb-rs232 converters but also a heap of info and links to even more. Anyway as for buying on the net or finding information try the link above and I'm sure you won't be disappointed.
Cheers Bryan1
note: this isn't an advertisment for Don I just find his site an insipiration to electronics especially the simmstick
bryan1 is offline
