Originally Posted by banh Don't quite understand. For example I read the MAX6501 datasheet, and it says MAX6501.MAX6503 have an active-low, open-drain
output while The MAX6502/MAX6504 have an activehigh, push-pull output. |
It's similar to an audio amplifier, in that you have two output devices - one connects between the output and +ve, turning this ON forces the output HIGH. The other connects between GND and the outout, turning this one ON forces the output LOW.
Often a logic output won't do this both ways, perhaps just having a transistor from output to GND, and relying on a simple resistor to pull the output high when the transistor is turned OFF. This is one reason for the 'fan out' limitations on some logic outputs.
