| I just found a part on an semi-old telephone (5+years) and i'm wondering what exactly the part is. description: its a small black box, looks like a small relay (really small) about 3/8" high and about 7/16" long, bottum is concave a little and has 5 pins coming out in this pattern: (o=pin) ----------- | o| |o o o o| ----------- i hoping its some really small relay, and it does have enough pins to be a DPST. reply if you need more info, thanks.
__________________ w00t! | |
| Good day BD, Does your part have any markings, or part numbers? Do you have access to a digital camera? Maybe a clear snapshot would help someone to determine the gem that you have. | |
| all it says on top is "55E"and then a "e" below the big E and as for a picture i thought i could get away with a discription because the part isn't that complex, its simply a small black box with 4 pins equally spaced on one side of the bottum and only one pin on the opposite side near the right.
ALso, quickly with a DMM try measuring the ohms through some pin combinations for possible clues... for example, if it is a relay and happens to have a normally closed contact pair, you should be able to find two pins that look shorted that are not shorted externally.. or it might be a passive part like some coupled inductors or a pulse transformer.. It might be a semiconductor and that one odd pin by itself could just be there for mounting purposes and not connected to anything. | ||
| well i did get dementions above, so there is the size. (width and height are the same) lets say these are the pin numbers: .....1 2345 the only thing i can find is that pins 3&4 have very little resistance between them, all the rest seem to have no connection. and i have tried using LEDS and then applying voltage to various pins and nothing happened.
| That's an Illudium PU-36 Explosive Space Modulator. Be careful with it. | |
| No wait, ur all wrong . . . That is the continuum transfunctioner . . . it's power is exceeded only by it's mystery. no seriously, I typed in 55E n 55Ee in google n couldnt find nething
| They used to put explosives in the phones but they decided it was sufficient that people exploded when they got the phone bill. | |
| first you give me pleasure...then I'll give you the continuum transfunctioner The part is still a mystery to me, sorry. | |
| blame the IRA | |
