| I recently removed a lcd panel out of a 2.4 ghtz wireless phone base. It has 12 pins and displays a 8 segment number and a little clock. Is there any way to decipher the pinout of this little thing? Probably next to impossible right. thanks Heres a picture ![]() | |
| is there any kind of chip on the back? | |
| Ok here is a picture of the back but there is no chip. I figured I would have to build some type of driver probably using a PIC. ![]() | |
| I would suggest it's a great deal of work, for very little gain, much easier to use a ready built text LCD module (or a graphic one). A bare LCD requires AC signals, so you have to arrange for that - the chip that fed it in the original phone probably had that already implemented in it's hardware - it's a fairly common feature of some micro-controllers. | |
| But it would be pretty easy to create a pulsed signal with a pic. I doubt I'll be able to get a pinout for it theres probably pretty hard to trace it back on the phones pcb. Maybe if I get the pinout for the phone's chip. | |
| I agree with Nigel. With little number of pins, this is a "topology multiplex" type display, so it have only two or three backplane pins for all digits. Need staircase signal for proper driving (to avoid the DC component) | |
I've just got back from the pub! 8) | ||
i've been looking for a simple lcd too, i've tryed taking them out of phones like Monkeyman87 did, but it's too much work to get them working, whats a good lcd to buy? | ||
To use a bare LCD display you've got to either use an LCD driver chip, use a micro-controller with one built in, or make a discrete driver system. I seem to remember from years back you used to feed the LCD pins from the outputs of XOR gates, with one input fed from an AC source - to give the required AC drive. If you're making 100,000 of the item, it's perhaps worth the saving - but for a single item, or a few hundred, it's not really worth the time or trouble. | ||
