Old 8th April 2003, 02:00 PM   (permalink)
Default Transistor Compatibility
Help required please,
I am a newbie to the electronics world (although I am very capable at soldering wires together). I am currently building a capaitor discharge unit which specifies a TIP31 transistor (which are rated at 40 volts) . Can someone tell me if I can use a TIP31C (rated at 100V) instead. my peak voltage in the circuit is approx 20V. I have been searching everywhere for this info but have so far drawn a blank. :?:
Shauno
Shaunhi is offline
Old 8th April 2003, 02:52 PM   (permalink)
its OK to use it.
bogdanfirst is offline
Old 8th April 2003, 10:59 PM   (permalink)
40v is the max it can handle if i'm not mistaken, so if you use anything >20v you should be ok.
thanks,
david
daviddoria is offline
Old 10th April 2003, 12:48 PM   (permalink)
yes, pardon me, anything <40v should be ok
thanks,
david
Old 10th April 2003, 03:13 PM   (permalink)
i think that you mean >40V
Old 10th April 2003, 03:50 PM   (permalink)
Shauni, just so there's no misunderstanding,
the tip31 is good for 40v and the tip31c 100v....if your circuit supply is 20v then the tip31 is ok... 8)
Chippie is offline
Old 10th April 2003, 04:25 PM   (permalink)
Nice avatar Chippie.
12C508/9? Oh what fun.
Pilot is offline
Old 10th April 2003, 04:34 PM   (permalink)
i think that we didnt misunderstand....
here is what i understood. in the circuit the transisto needed was TIP31, but this guy has a TIP31C and wants to know if he can use that instead of the one in the schematic.
and yes, the both work if the circuit is powered with about 20V
Old 10th April 2003, 05:58 PM   (permalink)
Thanks Pilot, its supposed to be an animated GIF, it normally rotates, but to get it here I had to reduce its size and lost its spinning properties in the process :cry:
Its also my avatar on lots of other boards too, if you come across me 8)
Chippie is offline
