| I'm currently playing aound with some IR LEDs and recievers, but the reciever is acting weird. I'm using the simple scematic from this page but whenever i plug 5V into the circuit, the led lights up even if the IR LED isn't activated. It looks like the IR receiver is always letting current trough, even if it doesn't receive an IR signal at its base. What can be wrong? Is there a possibility that the receiver is broken? Cheers! Lac. | |
| did you try it in complete darkness? this circuit will act on abient light also. | |
| Sec, shall try it now. Cheers. Lac. | |
| nope. still it acts weird, even in complete darkness. Cheers! Lac. | |
| well, it's pretty basic, there can't be much wrong... are you sure you're using the right transistor (NPN) and phototransistor? | |
It's a really crappy circuit though! - what are you trying to do with it?. | ||
| Meaby adding an potencimeter to adust sensetiverty.
| ohh... I just noticed that I have got a IR-Receiver, not a Phototransistor. I thought that IR-Diods used IR-Receivers, while Photo-Diods used Phototransistors, or am I wrong here? Whats the difeerence between photo and IR diods then? and what about the ir-receiver and the phototransistor? Cheers! Lac. | |
| How cod you mistaken an IR reciver(3 pins) whith an foto transistor(2 pins). An photo diode shod work instaed of an photo transistor. Here insted of an photo transistor an photo diode is used On pic1 the rele coil stops geting power in the dark.On pic2 i its the poposite Wait a minute...Ops
| O and replace R1 or R4 whith potencimeters to have the sensetivety ajustable
There are at least 4 or 5 common carriers that I am aware of. Just to make thing interesting, each IR receiver usually can only detect one of them ... Then there is the other little problem where each IR receiver is usually tuned to a specific IR wavelength. Granted while 980nm seems to be the mid-range and most can see a little either side of this, you've still got a large bandwith to try to cover if you don't know the frequency response of the receiver. Since an IR photo-transistor costs about 15 cents, I would have though buying a real photo-transistor would be the cheapest way out. Not saying it can't be done, but I'm kinda curious how you're going to do it without generating a carrier signal for the IR receiver. - Edit to fixup dumb spelling mistakes. Gotta layoff of the red wine | ||
| That's why I asked what the application is. If he wants to use it with a remote control he already has (for a TV, video,...) then it'll work fine with the ir receiver... Almost all remote controls use a 38 - 40Khz signal wich is what the receiver will repond to | |
| Cool, just checking Except a lot use other "weird" frequencies, some as high as 56khz... Not meaning to be difficult, but | |
