| Hi. Using PWM to control a motor has the same affect as lowering the voltage, and I wondered if any one could think of a way of measuring (in the circuit) the 'apparent' voltage - i.e. the voltage that would be needed to make the motor spin at that speed. Or measure when the duty cycle went beyond a trigger point. Not for any particular project, just thought process going around in my head. Cheers, Tim | |
| just measure it with your digital voltmeter, it will give the average voltage | |
| oh really? ok, then, but I don't want to know the actual voltage, but I want to measure it with something like an op-amp, to compare the voltage. Would the op-amp measure the average voltage, or would it operate too fast and keep changing? | |
| Tim, [quote= Using PWM to control a motor has the same affect as lowering the voltage, [/quote] Actually PWM is much better than lowering the voltage, you get a significantly higher torque from the motor and better control of the rpm. Ante :roll: | |
| | (permalink) | ||
| Styx, I did not say it was perfect (even the sun have spots) only much better, and it is! Tim, You can set up the op-amp to measure the average voltage if needed. Ante :roll: | |
Thanks a lot guys!! | ||
| | (permalink) | ||
what you want to do is use a low-pass filter to average out what teh voltage is. You will need to buffer the PWM signal first to stop the low-pass filters imedance messing with the PWM. The cutoff freq of yr low-pass will be based upon what your switching-freq is | |||
