Old 5th August 2004, 04:09 PM   (permalink)
Originally Posted by Johnson777717
So my transistor was protected and Johnson is trying his best to hijack my thread.
Relax, just asking a question.
A little knowledge is a dangerous thing. I'm living proof :twisted: :twisted:
The first rule of mstechca club is do not talk about mstechca club.
http://www.electro-tech-online.com/s...induser&u=1245
2camjohn is offline
Old 5th August 2004, 05:22 PM   (permalink)
Originally Posted by 2camjohn
Thanks for all the help guys, I will do the tests now.
I thought the test I have already performed was sufficient to rule out the transistor: Using an almost dead pp3 to power the motor stopped the relay holding ON at all.
The relay is definately a 6V, but the click is nowhere near as audible as other identical relays I have on other boards.
I like the idea of using optocouplers, but they seem to be such tiny devices.
Can they handle alot of power?
Does anyone have any links to websites which cover optocouplers.
Eventually I want to be able to switch 2A at 9V with a 6V signal.
Ill post back once I have done the tests.
Cheers
John
Opto relays: http://www.mpja.com/listitems.asp?dept=133&main=132
TillEulenspiegel is offline
Old 5th August 2004, 07:15 PM   (permalink)
Cheers dude,
But I have a small optocoupler here http://www.optocomponents.com/Quicklist4/SFH618A-2.htm
Could i use this with a couple of transistors to produce the results I want (Switching 2A @ 9V with a signal of 6V)
2camjohn is offline
Old 5th August 2004, 10:42 PM   (permalink)
Yes if you want , I'd use a TIP120, It's a darlington pair in a to-220 case ( sorry American convention) , but there are solid state relays that will do the job and all they need is a 3-30vdc input and the outputstage is what ever you select
Old 5th August 2004, 11:29 PM   (permalink)
100nF capacitors are good for this sort of problem. One across the motor brushes is my best bet. Next try one across the PIC power pins. Also check that no PIC pins are programmed as inputs and left floating.
spuffock is offline
Old 6th August 2004, 03:25 PM   (permalink)
TillEulenspiege:
Thanks I will try that circuit now.
spuffock:
There is already a capacitor accross the motor brushes of the motor, but the old motor (which worked perfectly) did not have one.
I will try putting a capacitor across the pics power rail.
I only have 10nf, will that produce the same effect?
Thanks to all who have helped so far
2camjohn is offline
Old 6th August 2004, 05:22 PM   (permalink)
Try a 2k pull down resistor between the pic and the 1k resistor.
M3S90 is offline
Old 7th August 2004, 02:35 AM   (permalink)
Yup That was my first inclination. IIRC the PIC I/Os are tri-state which means they float unless active. Don't know the logic convention I think it's active on ( Pos logic ). Don't use a 2k tho use a 10k after the 1k.
Old 7th August 2004, 09:30 AM   (permalink)
you don't need a pull down on a pic...
if the pin is declared an output it can source AND sink....
if the pin is floating then he made a software error...
Exo is offline
