| Hi. I came accross something on the net that was talking about regulators. It mentioned the whole virtual ground thing, and said that if you have a (for example) 5v reg, you can make it give 6v, but if you have a 6v reg, you can't make it give you 5v. 1) This set me thinking. To get a 5v reg to give you 6v, you give it a ground that is equivelent to 1v, yeah? So if you had a 6v reg, and you gave it a ground equivalent to -1v, would it give out 5v? This is just a hypothetical question. Oh, and for negative regulators (e.g. 79xx series) does the input have to be negative? Cheers, Tim | |
| | (permalink) | ||
| This is something I have done with fixed regulators like the LM78xx series. You can insert a diode in series with the centre ground pin, and alter the output by 0.6 volts. I have put in 2 diodes before, but this "trick" gets unreliable with any more than 2 diodes. | |
Cheers Nigel, Tim | ||
| Yes, it makes the output rise by the voltage drop on the diode. I did it with 1n914, or similar, when I couldn't get a 6 volt regulator, only had 5 's on hand. Never tried lowering the voltage. | |
| Why not use voltage divider to obtain reference gnd when increasing outptu voltage? It looks just like with LM317... | |
| Zevon, The “trick” works fine at least with 5 diodes maybe more (I have not tried with more) and if you need higher voltage use a zener of whatever voltage to add to the regulators voltage. Remember to turn the zener the other way. Ante :roll: | |
| True, Ante, it works with more, but I always had problems when I ran more that 2 or 3. Even the data sheets show this "trick." Perhaps it was the diodes I used, or something. Similar things can be done with the LM317 series, at really high voltages using a zener and a divider network, all that needs to be done is to stay within the i/o differential voltage between the sense and i/o pins. Good point, thanks for adding it, Ante. | |
