Old 31st July 2004, 03:42 AM   (permalink)
Default Diesel exhaust brake controller
My Dodge Cummins truck has an exhaust brake and it uses a signal from the ECM to activate the vacuum relay to engage the brake. I would like to make it a little smarter by having it automatically disengage below 15 MPH. I can get the signal from the VSS (Vehicle Speed Sensor) that is used for the ABS system. I can then process this signal to give me an enable or disable signal in relation to vehicle speed. I'm thinking of using a 555 and using the VSS signal to reset the timer if it's fast enough. Any ideas on other ways I might accomplish this?
Don\'t need no stinkin\' spark plugs!
Geartech is offline
Old 31st July 2004, 12:00 PM   (permalink)
What type of signal do you get from the VSS - voltage based, or frequency based (or something else, maybe??). How does the signal change in relation to vehicle speed?
Phasor is offline
Old 1st August 2004, 10:22 PM   (permalink)
It's frequency based. The pulse train increases in frequency in relation to the speed of the vehicle.
Geartech is offline
Old 4th August 2004, 02:44 AM   (permalink)
Well... I have no idea how to use 555s , but I know a great deal about the system you are using. (Vehicle Speed Signal)
Its a 5V signal that is connected to a hall sensor on you ABS tone ring. When a tooth goes by the sensor your signal wire is driven low (body ground).
I'm doing somthing similar that uses the vss, but I do all my work on PICs.
My guess is that the hardest part will be getting your timer to know when X number of grounds per second is 15mph. For me, (using a pic) I just set an interupt to count lows and then every second I check an see how many I have... Multiplied by the number of teeth I have, divded by my gear ratio, etc etc I know how fast I'm moving.
I cant be much help with a just hardware approach. I'm dumb and can only figure out processors (go figure).
But it sound very possible.
iso9001 is offline
Old 4th August 2004, 04:51 PM   (permalink)
I wish I had paid more attention in the Microchip seminars! ops:
Geartech is offline
