Old 28th July 2004, 10:23 PM   (permalink)
Default USB cable extension possible..???
Well..
my goodness.
i'm now relieved in a pump project..
there is only one porblem the pump is stucked in the hole in the ground.
@ aproxx 40 meters..
i want to let down a Web cam (whit light..) to look @ it..wy it is stuck..
has any one a idea how i could make the webcam..
work whit suchs a long cable
i was thinking of using UTP Network cable..
and maybe a voltregulator 5volts and battery..also near the cam for enough power..??
TKS
TKS is offline
Old 29th July 2004, 12:50 AM   (permalink)
I don't remember by heart but I think the USB is limited to some 4m
or so. This can be overcome one or two times by using hub and
that's pretty much it (or somewhere close). You can try to cut the
USB cable in the middle and splice it with your own 4-wire shielded
cable. I wouldn't expect it to work on ca 1000% above spec but
it you do try it let us know if it workes.
As an alternative, you can google for ethernet cameras.
Maybe someone else has better idea...
panic mode is offline
Old 29th July 2004, 09:36 AM   (permalink)
Default usb cam...
is the problem
the 5volt power...(usb is limited to 500ma..)
or is it the signal..??/
TKS
TKS is offline
Old 29th July 2004, 10:10 AM   (permalink)
Under specifications, the maximum cable length is 5m. Using hubs, you are allowed to extend up to a maximum of 30m. The problem lies with the signal. When electrical conductors get too large, their resistances/inductance/capacitances come into play to lead to signal distortion.
You can try pushing the limits, but there's no guarantee it would work. Why not hang a wireless camera? It could work, albeit at lower resolutions.
checkmate is offline
Old 29th July 2004, 10:21 AM   (permalink)
Default will
try to..
extend the cable..
network cable should indeed work fine..???
maybe the signal from a camera aren't that 'touchable.'
aren't there any amplifiers..?
TKS
ps 2 if the camera works whit the cable rounded it up (round 25cm) would it then also work if you pul the cable straight..?? (40m)
TKS is offline
Old 29th July 2004, 11:05 AM   (permalink)
Default Re: will
In theory, yes. It may work better as induction in a coil will cause loss of signal.
McGuinn is offline
Old 29th July 2004, 03:10 PM   (permalink)
Default ok
today we are gonna know it...
TKS
TKS is offline
Old 29th July 2004, 03:43 PM   (permalink)
if itz a low speed usb device, u could use usb extensions to a certain length. (altho u cud use a repeater every 10M to help overcome the signal loss
even beta is u cud use a camera what uses a standard phono cable
andrew2022 is offline
Old 7th August 2004, 03:24 AM   (permalink)
i would go with just the USB hubs make the cable longer that way the signal would not suffer as badly. that would probly be the easest way to do it as well.
it\'s not volts that kill, it\'s amps
batman24 is offline
